T-trim installed on 382ab
Old Dec 7, 2004 | 08:19 PM
Caveman's Avatar
10 & 11 Second Club
Default T-trim installed on 382ab
Finally got the T-trim on my car. Mike, Jeff, Gary and TY at Next Level Perf. got my car done in short time so I can run the No Bull Shootout at Orlando Speedworld on 12/12. Mike spent last night until 11pm tweaking the AF and timing so my car won`t detonate with the non FI Agostino heads. The car was very tricky to dyno with a TP 4400 Yank and T-trim. The best pull was 570rwhp,544rwtq with only 14*timing and 11:1 AF,on the first 2 pulls it was droping to 10:1 AF and below very rich! The converter was slipping 500-600rpm on top. He dynoed w/closed cutout because it was late at night and theres homes nearby. I waited for 7 months for Jay at Absolute Speed to do my 6.0 FI stageIII heads that I paid for in June, I finally gave up and had Mike Norris order me some AFR 225s. Hopefully by the end of Jan I`ll have the heads and a tighter converter and I can get some big hp and quicker times.
Red 98 Formula, Suncoast hood
382 allbore Norris/MTI shortblock
Wiseco pistons, Manley rods preped by CRE(Orlando)
Vortech T-trim RMCR kit (10lb for now)
Agostino Racing stageIII heads 2.08,1.60
Fast 90 intake,throttlebody
Century stageIII 4L60E
Yank TP4400
Strange 12 bolt 3.42s
BMR+ Spohn everthing,Hals
Old Dec 7, 2004 | 10:02 PM
MelloYellow's Avatar
Cgrats!
There's more in your setup when you get her all straightened out.
Old Dec 8, 2004 | 11:38 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Nice!
Wow 14 degrees of timing is pretty low, you going thru an aftercooler on 93 pump gas?
Old Dec 8, 2004 | 01:22 PM
Got Me SOM's Avatar
yea he is, i think mike kept the timing down to avoid detonation since he's over 11:1 compression.
Tell you what i've never heard a supercharged rev so quick, its almost like a turbo.
he has full power in like 4 seconds. must be from that gihugic verter.
Old Dec 8, 2004 | 09:05 PM
Caveman's Avatar
10 & 11 Second Club
Nice!
Yes 93 and aftercooler. Mike Norris wanted to make sure it does`nt detonate with the 11:1 ARE heads. He did 7 dyno pulls to get the AF set, he took the timing back from 16* to 14* just to be safe, it did`nt detonate once. If Jay would have done my 6.0 FI heads it would be at 18* or 20* timing and making alot more HP. I`ll have AFR 225s by the end of Jan hopefully. The rpms come up real fast with the TP 4400 Yank, which is now flashing to 5000(should launch real hard if it hooks). What converter do you have in you setup John?
Old Dec 8, 2004 | 09:39 PM
CHRISPY's Avatar
nice numbers!! Should consider running race gas at the track for added protection
Old Dec 8, 2004 | 10:24 PM
Caveman's Avatar
10 & 11 Second Club
Good idea, I plan to thanks.
Old Dec 9, 2004 | 10:33 AM
LS1Tech Co-Founder
I'm running a Yank TP4400 that was flashing to 4300 on the dyno and on the brake. I sent it back a while ago to have it freshened and I also asked Mike to loosen it up just a bit since I wanted more shift extension.
Old Dec 9, 2004 | 11:10 AM
Got Me SOM's Avatar
psj don't you have a turbo 400 or did you switch back to an a4?
Old Dec 9, 2004 | 11:41 AM
LS1Tech Co-Founder
I have a Yank TP4400 for T400.
Old Dec 9, 2004 | 12:42 PM
Got Me SOM's Avatar
Ahh Ok.
Old Dec 9, 2004 | 11:31 PM
Caveman's Avatar
10 & 11 Second Club
So I guess you like the way the car runs the 1/4 with that converter if your keeping it and getting it restalled? Wow I did`nt realize you had the same size conv. and made 750rwhp thats impressive. I was thinking about a Vig 3800 w/5 clutch setup. If a conv that loose(TP4400) will work I`ll just keep it and get it freshened up, I`ll know if I still like it after this weekend with our LS1 race in Bradenton and No Bull in Orlando the next day.
Old Dec 10, 2004 | 10:39 AM
LS1Tech Co-Founder
My Yank flashed to 4300 on the chassis dyno.
It was dropping to 5500 on shifts. I was shifting at 7000.
To tight of a converter and you will have big drops on your shift. Too loose of a converter and you will spend most of your run in 3rd gear.
I sent my converter back since it was convenient to get it checked, and it was used from a friend. If it flashes more to around 4800 I'd like that. But that's going to make the car a wee bit less streetable.
Old Dec 10, 2004 | 11:01 AM
Got Me SOM's Avatar
i think a 3800 will be perfect im sure the shift extension is the same as mine, at 5,000
Old Dec 10, 2004 | 11:23 AM
LS1Tech Co-Founder
I think a true 4000 is good for a street car depending on your shift points.
