how much oil for turbos?
Guest
Posts: n/a
ok, i have twin 54mm garretts on my truck(5.3), and they are almost ready to be fired up. one of the last things i need are to run the lines for oil.
how much oil can do i need? 60+ psi is too much right?
im using -4 feed line and -8 return
Thanks,
Dan
Thanks,
Dan
I would suggest 3an lines... with that pressure and volume you will most likely develop oil seal problem. many people are using restrictors on the pressure side. turbos only require 10-20 psi of pressure...
