ATI Guys, what pcv setup you running?
Kyle
OK if you live in Florida and always run long trips it could be fine, but in my case (cold winters and short trips) I think I really need a forced ventilation, or all the water condensation will remain in the block.
This of the headers sucking air through the engine is good! No PCV valve, no catch can...
Is it fine also if you have cats?
Kyle
CORRECT Kyle
I don't understand why people use the check valve. We know we don't want to "boost" the crankcase but you have to vent it especially with FI. No offense intended Tici. Just the blower drawing vacuum. Kurt at Wheel to Wheel said this is the best way to run it. They run it the same way on their FI cars for the most part. I consider him one of the experts for FI on LS1's. After all they have been involved in most of the high horsepower FI motors on this board not mention they may be the first group into the 7's in 05'. My whole set-up cost me about $50. Catch can from Jegs (slightly modified to fit where I wanted it) a couple fittings, and some fuel grade hose. Good luck!
Mark
I run the LS6 style pcv setup and I am using the fresh air source from the blower inlet also. No catch can. I haven't noticed any oil in my intake track. I have no consumption issues either.
In my case I see oil and water in the catch can and if it overflows I really prefer have it directly in the manifold than going through the blower...
By running the oil catch can like this, there is one draw back, I change the oil more often since the oil gets a little more dirty running a vent system VS a PCV system. The change is very small. Also, pushing as much power as I am the oil life goes away faster anyway. Well that is just my 2 cents..
Clint
Yes, you can feel the suction if you pull the PCV hose off the valve cover and crack the throttle with your thumb over the hose. Seems to be a perfect balance...no problems at all here. BTW a well balanced set-up will yield very little oil in the catch can. More moisture than anything.
i have to check again, but last time i popped the oil cap i had a choo choo thing going on, i hope i didn't crack a ringland. arghh
Where is the small overpressure coming from? (...I can feel a steady stream of vapor coming out of the hose...)
I actually don't have a problem with the PCV, but there are so many informations around (right or wrong I dunno) about PCV and 98 engines, oil residuals in the manifold, pinging because of that oil...
I'm just trying to figure out how it really is. There are also independent electrical PCV systems (pumps), but I don't have a clou if it's really necessary to go so far.
Stefano
Some people use a pump on their hot rod that is belt driven, these flow alot of air and will work for a FI car, but it's hard to setup and expensive. Some people have tried the old school way and run a line to the headers and allow the exhaust pressures to draw out excess vent from the motor. This setup works very well and provides plenty of neg vac for the motor. Problem is, you cant run this setup on a full exhaust. I've heard this can only work for a open header echaust system..
Clint
if your car is at idle and your blowing smoke out of the oil cap, that's usually a blown ring land right? what are the chances that my pcv system is clogged or cant keep up? where do i need to look to check?
packy-think i'm dropping my car off to norris this week. hopefully gary can fix the problem cheaply
otherwise i gotta rob a bank to get my motor done.
I hate to say it but that is exactly what my car was doing before the motor went...
Mne was huffing smoke out of the oil cap and every once in awhile the dipstick would fly out.
I had 3 broken ringlands and a lot of worn out rings on my stock LS1 motor.
I hope you don't have any major problems.
How much did Norris charge you to do a forged shortblock?
