Turbo Question.........
Old Dec 13, 2004 | 01:55 PM
kcshaner's Avatar
Question Turbo Question.........
What are your thoughts on this turbo for a 355 LT-1 with forged internals single turbo set up? Any pros or cons?
http://www.hksusa.com/products/?id=817&rsku=
Thanks in advance
Old Dec 13, 2004 | 01:57 PM
777's Avatar
777
cons...$4000...pros lots of power
Old Dec 13, 2004 | 02:14 PM
kcshaner's Avatar
Its the power I want I am considering buying a turbo Z from a guy here in town and I am doing as much research on the car and its parts has possible. I was told it was a good/big turbo, but I have only had superchargers and I am not very sure what makes one turbo better than another.
While I am at it, it has a 52mm throttle body on it, should this be upgraded?
Also, he has the stock MAF and an after market larger MAF but he says there is to much turbulance in the larger one because it has no screen, should I stick with the stock one, or go with an oftermarket unit.
Thanks for your reply
Old Dec 13, 2004 | 02:22 PM
777's Avatar
777
i don't know about the maf's but i would get a larger throttle body and i'm in the same boat as you...actually a little worse since i'm an n/a guy...i researched a little about s/c's because i was about to get one, but i never really was that interested in turbo's even though they make more torque by the way i don't really know what he is talking about with turbulence...our maf's aren't screened..
Old Dec 13, 2004 | 02:40 PM
kcshaner's Avatar
Hmmmmmm interesting about the MAF, I will have to look into that. Thanks for the responce and I wish you luck with the s/c.....if you get one!
I think I will sell the 52mm for a 58mm.....Thanks again.
Old Dec 13, 2004 | 02:58 PM
777's Avatar
777
yeah i don't think i will...unless i get tired of this h/c i'm putting in soon....then i'm going with a 408 and either a twin turbo or an ati setup...i'm so confused on forced induction because i've been into n/a mostly
