Update on my car,(major diet)
Old Dec 14, 2004 | 11:22 PM
BIGBOS's Avatar
Whats the motor setup going to consist of?
Old Dec 15, 2004 | 01:02 PM
1fastWS6's Avatar
Looks really good! Is that a backhalf kit your using??
Old Dec 15, 2004 | 05:39 PM
U-Luze's Avatar
Only thing that I could really use out of the Kit was the main hoop. I had to cut the rear frame rails and everything and redo them, The kit is from Chassisworks. Now i have to get a the front rails bent up. Had i had it to do over again i would have it bent myself and saved alot of money. Cause its all pretty much straight bars.
Bos Motor will be iron block, same billet crank i have in it now,change out the eagle rods and put either oliver or some carrilos in there and keep the pistons and all that stuff the same. Ill have the girtle added and jesel belt drive installed and distributer conversion. Switch over to solid roller valve train. I have found a set of C5R heads that have had the chamber cut too deep and will be perfect for a FI app. And have found a set of turbo headers that Invisible Sun had that wouldnt work for him. I still have some other stuff to sell before i can buy all this other stuff. So i imagine it will take a lil while.
