Larger Turbo Question
Old Dec 14, 2004 | 02:49 PM
RisingSun's Avatar
Default Larger Turbo Question
I've got a Qmp turbo kit with the pt 63 turbo but I want to upgrade to larger turbo, Something that will bolt in without modifications. What are you qmp guys running? Thanks
Old Dec 14, 2004 | 03:11 PM
turbochad's Avatar
I am running a T76.
Old Dec 14, 2004 | 04:16 PM
MIGHTYMOUSE's Avatar
if you have the one that came with the system it is rated for 745 flywheel hp. how much boost are you running?
Old Dec 14, 2004 | 06:35 PM
RisingSun's Avatar
I'm running about 7 lbs.
Old Dec 14, 2004 | 07:39 PM
now tell me again why you want to upgrade to a larger turbo?
Old Dec 14, 2004 | 11:23 PM
RisingSun's Avatar
Cause my turbo that I have now is leaking from the oil seals, and might as well go bigger. He he!
Old Dec 14, 2004 | 11:35 PM
RisingSun's Avatar
But my budget is tight so I'll go with any other brand turbo that will fit, and is the same size as pt 63.
Old Dec 15, 2004 | 09:14 AM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Just go with a PTE-76GTQ. That will bolt in to the system with very little modification if any.
Jose
Old Dec 15, 2004 | 12:15 PM
if your budget is tight why not get the one you have repaired? heck they may even cover it under warranty as you just have a leak.
Old Dec 15, 2004 | 02:24 PM
RisingSun's Avatar
Repair sounds like a good idea, the only problem is that I only have one car. If its not under warranty how much does the repair cost? Any idea on a typical price on a rebuild.
Old Dec 15, 2004 | 02:37 PM
SUPER DAVES Z's Avatar
Just got a T76 rebuilt by TTi. Cost $475 out the door, not real cheap if you ask me. Yours might be a little cheaper but probably not much.
Later,
Dave
Old Dec 15, 2004 | 03:05 PM
RisingSun's Avatar
Thanks Dave. And Jose I just went on your site, prices on your turbos are pretty good.
I was thinking buying a new turbo like another pt63 and sending my old one for rebuild later. That way I have a spare just in case...knowing my luck with breaking things.
Old Dec 15, 2004 | 04:00 PM
if its not your fault i dont see how they could charge you more than parts cost which is a couple hundred, and if you put your story to them right i am sure they could turn it around inside of a week.
Old Dec 17, 2004 | 01:18 AM
RisingSun's Avatar
Thanks everyone for the info,
Hardy
