Head Gasket Selection?
Old Dec 19, 2004 | 10:17 PM
MadMike93TA's Avatar
Default Head Gasket Selection?
What kind of head gaskets would you all use for O-Ringed LT4 Heads, running about 10-11psi with 9.3:1? Thanks Guys...
Mike
Old Dec 20, 2004 | 12:05 AM
Arkangel77's Avatar
Not sure about the Oring thing BUT I used MLS COmetic head gaskets!
Old Dec 20, 2004 | 07:29 PM
95zpro's Avatar
Any suggestions where to get them; I just blew a head gasket a few weeks ago and was going to spend the holidays working on them?! Did you get them directly from cometic?
Old Dec 20, 2004 | 09:57 PM
Arkangel77's Avatar
I think I got them threw A distributor. I cant remember where BUT they are AWESOME! You can get them in different Thicknesses and from what the Builder's that I spoke with said they were SUPPER strong and could hold UP to Crazy boost levels! I was told there was practically NO reason to Oring blocks anymore now that they came out with these! Good Luck, Lata, Ark
Old Dec 21, 2004 | 08:14 AM
95zpro's Avatar
Thanks Ark, you tha man! That is what I'm going to get for my rebuild.
Old Dec 21, 2004 | 09:06 AM
onfire's Avatar
Coal Mining Director
Don't use Cometics if you have o-rings. You need a stock type gasket with a steel firing ring around the cylinder to mate to the o-ring.
Old Dec 21, 2004 | 10:56 AM
Arkangel77's Avatar
onfire - may have a Point?
95zpro - You Might want to check into that! Just in case.
Good Luck, Ark
Old Dec 21, 2004 | 02:00 PM
mongse's Avatar
I ruin the end of films...
Mike
If you've already got the heads cut, I'd just run a copper gasket. Are you going to machine a receiver groove in the deck too? Really though, o-ringing @ 10# is overkill. 20#, I can understand.
I'll be switching to Cometic. If you haven't had the heads machined yet, that's what I'd suggest.
