Opinions on Intercooler Sprayers
Old Dec 20, 2004 | 01:50 PM
kcshaner's Avatar
Default Opinions on Intercooler Sprayers
I am considering purchasing an NX intercooler sprat Kit for my single turbo w/intercooler 355 ci LT-1. Does any one have any first hand experience with this kit or any other? What are your opinions, either good or bad?
Also, on a car putting down 498 rwhp how much more power could be expected?
Thanks in advance....
Old Dec 20, 2004 | 01:56 PM
860 Performance's Avatar
I have never dyno'd a car with an intercooler sprayer, but have installed plenty of them and here is what I know about them.
The NX N-tercooler uses 1 lb of nit every 8 secs which means you will use 1.5lbs every pass. That is a lot of N2O for the gain. It is much more efficient to spray a small ammount 50 or 75 shot. You will use less and gain more.
just my two cents.
Old Dec 20, 2004 | 02:54 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
I would agree with 860 that the 50-75 would make a huge difference in a boost application. the Ntercooler has seen 50+hp on chassic dynos on small engine displacement. It was created to help the guys that could not run nitrous. (class racing) I will be putting one on my truck in the near future.
Ricky
Old Dec 20, 2004 | 03:00 PM
cablebandit's Avatar
I am going to rig up something soon misting water on mine. It should be easy. I saw an Aussie installer report that water misting on them was worth 7% hp increase generally
Old Dec 20, 2004 | 03:01 PM
kcshaner's Avatar
WOW! I did not expect that kind of power. I am afraid my engine is about maxed out (due to the stock rods and crank) I thought the intercooler sprayer would make my car safer to run with an extra few hp's, perhaps if it helps that much it would be overkill.....
By the way, I have had nitrous and such in the past. Do the C02 kits come with different jets or does it just have a basic setting. Also, is there a WOT switch?
Thanks
Old Dec 20, 2004 | 03:02 PM
NXRICKY's Avatar
You could do a water meth injection system.
Ricky
Old Dec 20, 2004 | 03:40 PM
kcshaner's Avatar
Ricky
I am actually between the two right now, I am considering the NX Ntercooler kit or the Snow Performance injection kit and I cannot decide which one. I would get the Snow performance but my engine is maxed out as it is so I could not add more boost so it seems kind of worthless to go that route.
Old Dec 20, 2004 | 04:21 PM
I'd get the alky injection. Neither is gonna make a lot more power but the alky would greatly add to the safety on your motor. Much less chance of Knock using alky injection.
Old Dec 20, 2004 | 08:29 PM
kcshaner's Avatar
Do you reccomend any particular kit or things to look for?
Thanks.
Old Dec 20, 2004 | 08:52 PM
Thanks.
SMC
Snow
Razors kit
Can't recommend one over the other since I have only used the SMC that I have.
Old Dec 21, 2004 | 08:23 AM
kcshaner's Avatar
Thanks for the info, I will probably use the Snow kit. Another quick question for you....if I get the kit and hook it up but do not add more boost will I still gain any power? If so about how much?
Old Dec 21, 2004 | 08:46 AM
it will only allow you to add more timing so not much more power unless you add boost. i am in the same boat as you. I am somewhat limited to 15psi. Normally you would get your tune right on 93 octane....add alky and just increase boost.
In our case (since we are stuck at one boost level) we can add timing and/or be ultrasafe on our current 93 octane tune! What are you really trying to accomplish? If your tune is safe now and you don't plan to up the boost, don't buy alky kit. I got one cause it was 50 bux from a friend who didn't want it!!!
Old Dec 21, 2004 | 09:18 AM
kcshaner's Avatar
Well, for the rare occations that I might want to up the boost one or 2 lbs (track use or racing my brother in law) I thought it would be a good idea. However, if it had no positive effect unless the boost level is turned up I would not get it.......Who am I kidding, yes I would!
If I am safe now on 8-9 I may buy the kit so I can go to 10-11 on some rare occations. I noticed you are selling an air/fuel meter, please e-mail me at derek@shanerappraisals.com with more info. Also, how hard is it to install?
Old Dec 22, 2004 | 07:36 AM
Project GatTagO's Avatar
NOS makes a nice kit as well. It is adjustable so it will fit many different intercooler core sizes.
Andrew
Old Dec 22, 2004 | 11:04 AM
blownZ's Avatar
The nitrous intercooler sprayers are a sham. Tried it on my civic and picked up 40 WHP on the dyno. Then I realized it's because the nitrous sprays through the intercooler, and it's ingested straight into the turbo. The actual reduction in inlet temps was very minimal, but the motor was injesting the nitrous and that's why it made more power. If you want lower IAT's, run a meth kit like others have suggested. We run one on a friends 69 camaro with a twin turbo small block, and the pipe after the methanol nozzle feels cool to the touch, and when we dynoed it on a cold night there was actually condensation on it. We were seeing IAT's 15-20 degrees below ambient on the dyno spraying the meth.
Old Dec 22, 2004 | 11:20 AM
RealQuick's Avatar
For a street car not running in a race class where rules are limitting, I think its a waste to spray the intercooler with meth or nitrous. You will gain much more by spraying inside the intake tract rather than across the intercooler. I just think its a waste...JMO.
Old Dec 22, 2004 | 03:49 PM
I am going to log my IAT while 2 stepping my car...should build SOME heat. Then I will set my water host to spray on it and see the difference. If I don't see nuthin' ...nuff said but I'll let you know
Old Dec 23, 2004 | 10:00 AM
kcshaner's Avatar
That would be great....thanks my friend!
