13lbs of Boost made 781 hp to the wheels
Old Dec 23, 2004 | 05:07 PM
Turbo Ram Air's Avatar
Default 13lbs of Boost made 781 hp to the wheels
I currently own a 2001 Trans Am Ram Air with a Lunati 408 kit with 8:5:1 CR LS6 heads built by Merkel Racing Engines in Long Island.The car was put togther by TURBO PEOPLE out of Hastings on Hudson in New York,The car has a custom cam :cam: done by Turbo People and a custom turbo with GEN 7 DFI.The turbo kit itself is a Turbo Technology Race kit water to air intercooler.I took it today to the dyno with stock rearend with a girdle with 275/50/15 BF Goodrich Drag Radials and stock transmission with a Star 600 + HP clutch,my first run was 638 hp at 12lbs ,second was 760 hp at 12.5lbs ,third was 781 hp at 13lbs .I went three more times after that with the boost turned up to 15lbs and it kep spining the tires really bad on the dyno and was only making 520 with it spining at 90mph.With this turbo i have on the car the lowest i can turn the boost down to is 12lbs so im gonna be putting two wastegates on it to lower it.I will be heading back to the dyno with slicks next time and the boost turned up
Last edited by smokinHawk; Dec 24, 2004 at 06:35 PM. Reason: non sponser links removed
Old Dec 23, 2004 | 05:11 PM
Jammer's Avatar
Typical Job Jr. style numbers! Good choice.
Old Dec 23, 2004 | 05:13 PM
slow trap's Avatar
nice numbers,congratulations.what size turbo are you using?
Old Dec 23, 2004 | 05:23 PM
the turbo is all custom im not even sure
Old Dec 23, 2004 | 08:09 PM
jleews6's Avatar
Congrats on the numbers. When you have the some of the best in the country working on your stuff the results are usually great. Get that thing to the track and lay down some big MPH.
Merkel built the motor in my friends GN and it made 1200 rwhp.Twin t76 small block.
Old Dec 23, 2004 | 08:26 PM
Wildman's Avatar
Nice Numbers... How about some pics?
Old Dec 23, 2004 | 08:59 PM
goober35's Avatar
I hate you with a pastion. Can we trade cars. You have done what i want to do.
Old Dec 23, 2004 | 10:20 PM
Bryan Wilkinson's Avatar
Congrats sir on the great numbers
Old Dec 23, 2004 | 10:37 PM
MIGHTYMOUSE's Avatar
congrats on the numbers. i know it will back it up at the track too!
please pm me when they have the wastegate thing you mention figured out.
Old Dec 24, 2004 | 10:53 AM
Default Turbo
Thank you Guys ,it kinda sucked cause the BF Goodrich Drag Radials i had on it were old so when i we went to turn up the boost it just ignited the tires on the dyno.The boost was turned all the way down it wont go any lower then 12lbs so Job Jr said were gonna have to put a second wastegate on it cause one, the boost starts to kreep and two i need to turn it down a little to so i can play on the street without killing myself.
Old Dec 24, 2004 | 11:01 AM
Tiago's Avatar
great results, some more info on the setup would be nice
Old Dec 24, 2004 | 11:36 AM
gaga's Avatar
where are u from? westchester L.i. area?? IF so I definetly need a ride in that beast..
Old Dec 24, 2004 | 12:03 PM
wonder why they dont suggest a lower psi wastegate spring?
Old Dec 24, 2004 | 12:05 PM
*edit* i guess with all that CI you are outflowing the wg.
Old Dec 24, 2004 | 01:14 PM
Jammer's Avatar
I hope to see you again at the Lake... Lets get our turbo TA's together this spring. Congrats.
Old Dec 24, 2004 | 06:31 PM
Default Turbo
once again thank you guys, i cant wait to go to the lake next year we defintely got to meet up jammer this spring,ill defintely post when i retune it again with slicks and a taller tire,hopefully by then ill have a automatic in and a aftermarket rearend
Old Dec 24, 2004 | 07:24 PM
WS-Sick's Avatar
Very nice numbers! I plan on turboing my car next summer or maybe even sooner.
Old Dec 25, 2004 | 01:26 PM
2000 Tran Zam's Avatar
how large is the turbo? was 93 oct used, or race gas?
i am building a 408 motor with a gt55 turbo at FMS and am hoping for close to 700 rwhp on pump gas with similar boost.
