F1R Procharger with dry sump
In the final stages of a 410 ci buildup with a Intercooled F1R procharger.
Need some advice want to fit a 4 stage dry sump system using a underdriven ATI damper with a HDT drive for the dry dump pump.
Has any body done this yet and if so what problems if any have you encountered.
Drysumps on this board are far and few between. I would reccommend the ARE setup, www.drysump.com or the Daily engineering setup. Dailys is more money but has is benefits. Look them up and they can help on the pully/belt issues.
