Turbo-fuel system question...please help
55 lb/hr injectors
Racetronix in tank fuel pump
stock inline
I bought the Bosch 420 inline-fuel pump and will have it installed. Do you think that will be enough to run the car safely at about 520RWHP (that is what they are projecting the car to make) or should I upgrade the Racetronix pump to somthing else.
Also, would methonal injection be helpful to avoid lean conditions?
Thanks in advance
what is a stock inline?
Please ignore the stock inline comment
one 255 in tank alone should be more than enough for your goal. i suspect a crimp in the line somewhere or a possibly regulator related pressure issue.
