How is making BIG POWER without cooling the air
Old Dec 30, 2004 | 11:19 AM
Schurters LT1's Avatar
Default Who is making BIG POWER without cooling the air
Going 355 LT1 all 4340 built..how much boost with T-Trim and pump gas...just try to see who is making some big power or did a one point..and how much timing are yoiu pulling and where are you keeping the AFR..
Old Dec 30, 2004 | 11:21 AM
hellbents10's Avatar
LS1Tech Sponsor
Well I would consider using meth/water injection.
Old Dec 30, 2004 | 12:41 PM
Got Me SOM's Avatar
With methanol injection you can ruch more timing and you'll have to definitely richen up your air fuel.
I think its worth to go with a front mount and a small injection of meth for safety.
Old Dec 30, 2004 | 02:40 PM
MIGHTYMOUSE's Avatar
what is your reason for not intercooling?
Old Dec 30, 2004 | 03:45 PM
777's Avatar
777
yeah...that would be my question as well
Old Dec 30, 2004 | 04:06 PM
Just don't have the $$$$ this coming year to do a intercooler with doing the eng and T-Trim...my look at alky...
But what kind of power can be made with out cooling
Old Dec 30, 2004 | 04:34 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
I have asked several mfg's that question and all are saying 5-8 psi. Kinda funny they can agree even on that poiont. To many variables to say, start small and work you way until yu see a bit of knock then back it down.
Ricky
Old Dec 30, 2004 | 05:15 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Without intercooling, without anything injection, I would not try more than 9 psi with a 9:1 engine.
Old Dec 30, 2004 | 07:57 PM
Guido's Avatar
NMRA guys run in the 8's without an intercooler
[/devils's advocate]
Old Dec 30, 2004 | 10:25 PM
Well the CR will be 8:5.1 and on 94..I would like to see about 10lbs if i could
How much will alky help
how much boost could i run
how much timing could i add
how rich will the AFR need to be
Old Dec 31, 2004 | 12:15 AM
eviltwins's Avatar
I ran 14 pounds non intercooled, 93 octane on 9:1 compression 302 ford. GT40 IRON heads, a cobra intake, full exhaust, an S-trim and a good tune. 10 pounds on that motor non intercooled will be easily over 500 RWHP, it sounds like a good place to start on the street for me.
