Some promised update pics
Old Jan 2, 2005 | 03:34 AM
Jammer's Avatar
Default Some promised update pics..more added 1/5/05
SEE BELOW< MORE ADDED ...Stick a potato in my exhaust tip and make some french fries!
Of course there is one turbo on each side now.
.As seen below, we modified the T3 Inlet flange to work as a hanger on each side as well. Tokk a lil stainless scrap to do this.
. Cut the BMR track pack bar to mount more like a Spohn Body mount. This will clear the way for the exhaust pipe (andi IC pipe) to make a run from front to back just under the body. I'm using custom coated 2.5 " exhaust to each turbo, coming off coated Macs. Will use and H pipe as well for balancing.
Old Jan 2, 2005 | 03:56 AM
Jammer's Avatar
Heres a better view of the modified cross bar.
The picture below shows how the bar used to run from "frame connector to frame connector" before we cut it! That 4" exhaust is now on the shelf in favor of true dual 2.5's.
Old Jan 2, 2005 | 04:01 AM
Jammer's Avatar
more pics.
more.
Old Jan 2, 2005 | 08:10 AM
BigPlanTransAm's Avatar
pretty pretty.
i was thinking i woulve had to sell my x-brace if i got the STS but it looks like you guys solved that problem quite nicely. does it seem to effect chasis ridgidity any with it not being connected to the frame connectors anymore? also, doesnt the new placement effect the torque arm angle or can you use an adjustable torque arm to compensate?
Old Jan 2, 2005 | 08:16 AM
onfire's Avatar
Coal Mining Director
Looks sharp. Are you going to use one or two pipes to return the pressure side to the ic? Metal or silicone?
Old Jan 2, 2005 | 09:36 AM
Jammer's Avatar
I have an adjustable TA, so I'm cool there. A stock cross bar does not go side to side, it takes the same bolt holes we used.
Originally Posted by BigPlanTransAm
pretty pretty.
Old Jan 2, 2005 | 09:37 AM
Jammer's Avatar
Going to use metal IC pipe. Still havent decided if it will be dedicated 2" ID peices or split to one 3" ID pipe than split back. Probably dedicated.
Old Jan 2, 2005 | 09:46 AM
JS's Avatar
JS
Get rid of the plastic tie raps and go del clamps on all the lines.
 Michael S. Palmer
Old Jan 2, 2005 | 10:10 AM
Jammer's Avatar
Im all over that JS, that wasnt me, that was done by a shop I had previously hired to do some work. You know how that goes Im sure.
Old Jan 2, 2005 | 10:16 AM
JS's Avatar
JS
Yep do it yourself and it;ll get done right
Car looks wicked Jam...
Old Jan 2, 2005 | 06:20 PM
Slowhawk's Avatar
LS1Tech Sponsor
The only thing that bothers me is the exhaust feeding the Turbo's.How would you know both Turbo's will have the same amount of exhaust to turn them?The exhaust might favor 1 turbo more than the other causing boost problems..Just a thought.
Mr. B's Avatar
Looks great..
Old Jan 2, 2005 | 07:29 PM
BLk01SS's Avatar
I don't know. I think you could've of done better.
J/K looks killer. PM me if your still intrested in the T pipe. I'll probably sell it
Old Jan 2, 2005 | 10:09 PM
Jammer's Avatar
BLK: I did do better, but you bought my better kit. well, maybe, well see. I may want it back. Now Im just out to prove, or disprove something.
Slowhawk, I would expect each turbo to get similar air flow as 4 cylinders are feeding one turbo, and 4 cylinders feeding the other...Im runnnin true duals. The car is not lowered so Im not scared to run it under the floor boards. I had always planned to use oval pipe, but Chuck at Dr. Gas said oval pipe may not flow as well as round. I plan on an "h" to allow for some pressure equalization without disrupting flow too much. My main concern is if 2.5 is too big to keep velocity up. IO was afraid 2.25 may have been a tad restrictive. I kinda think I should gone 2.25. The entire exhaust will be ceramic coated to save some heat (went mild in place of stainless..had to cut costs somewhere in case this doesnt work well).
BLK: I do want the Bov Pipe if your ready to sell.
Thanks for the input guys, Im here to share the story, its part of the fun. Im not out to be a 1/4 mile master here and hold anything back.
Old Jan 3, 2005 | 12:26 AM
Arkangel77's Avatar
WOW - That Looks AWSOM!
Old Jan 3, 2005 | 12:37 AM
solobaric's Avatar
Very innovative man. Glad to see people willing to try something different. It can only help all of us in the long run.
Old Jan 3, 2005 | 01:40 AM
sr71bbjr's Avatar
If it were me I would run the charge pipes through the inside of the car and through the fire wall due to all the clearance isues under the car.
Old Jan 3, 2005 | 07:06 AM
Jammer's Avatar
The charge pipes are of NO concern..the Torque A m brace hanges an inch lower than the IC pipes.
Old Jan 4, 2005 | 03:24 PM
dman's Avatar
one question. those turbo mounts you made look like they are solid mounted to the rear frame rails. if so are you running flex pieces to allow the exhaust to move with the engine? Or do you have solid motor mounts?
Old Jan 4, 2005 | 08:15 PM
Jammer's Avatar
I have flex /mech (8") on each side to take some movement. Have the pipe run over the axel as of tonight. I'll post pics later.
