Iron or Aluminum Block
Old Jan 3, 2005 | 07:42 PM
Arkangel77's Avatar
Its COol Bro - there was NO harshness, I love reading you guys post. I have learned a LOT and I enjoy reading about the things you have tried, done, and going to do. Keep up the Good work, lata, Ark
Old Jan 3, 2005 | 07:56 PM
trtturbo's Avatar
For a street car and modest boost- 10 or so I would prefer the aluminum, but I am going the cheap way. I bought a bare iron 5.3 block; same as an LS1 block except smaller bore. (paid $45.00 off ebay). Use stock crank, good rods and pistons and ARP bolts. Bore to LS1 specs; 3.898 or .905 I think. This should work and save me a little money and be plenty strong.
Old Jan 3, 2005 | 08:33 PM
Wnts2Go10O's Avatar
Default re
Originally Posted by y2khawk
I run an aluminum block.
bastard...lol. j/k man. how many times have you had the heads off btw since the mad boosting? and yea im suprised a stock crank can hold that ****. speaking of strong stock blocks, wtf is up wth the rumors considering how strong the new ecotec blocks? ive heard they can hold 1000hp or somethin crazy retarded.
Old Jan 4, 2005 | 07:01 AM
TTSSZ's Avatar
90% of the people are not going to damage the aluminum block.
I here the same, 1000hp on the aluminum block, I also here the ls1 block is stronger then the ls6, even though the ls6 has better alum. The improved cast in 'windage' vent holes are larger and weaker then the drilled holes in the ls1.
I believe the cartek 1200hp TT vetts are both aluminum.
Old Jan 4, 2005 | 03:00 PM
Wnts2Go10O's Avatar
Default re
i would think theyd flex likea **** from the heat/boost pressures, etc. itd be very odd if the ls1's were stronger, more like not make sense at all. well that and im an oldschool kid, i like the iron. heres a question, what are the boost pressures on the 1000hp aluminum ls1's?
