Iron or Aluminum Block
Old Jan 3, 2005 | 01:10 AM
Kaneman's Avatar
Default Iron or Aluminum Block
What is everyone's opinion on an iron block verses an aluminum block for turbo cars?
Kane
Old Jan 3, 2005 | 01:25 AM
Wnts2Go10O's Avatar
iron holds boost better, period.
Old Jan 3, 2005 | 01:32 AM
sr71bbjr's Avatar
Iron holds everything better.Deside if you will need the extra support and 109lbs.
Old Jan 3, 2005 | 01:54 AM
y2khawk's Avatar
I run an aluminum block.
Old Jan 3, 2005 | 03:03 AM
LSs1Power's Avatar
Enough said.... Im sticking with my aluminum block after what Harlan did with his.
Old Jan 3, 2005 | 03:05 AM
disassembled's Avatar
It depends on your goals. If you're going to stick around 600hp or less then aluminum would be fine. If you were going higher aluminum would still be fine but iron would be more consistent (wouldn't expand and contract as much) and would be a little sturdier. My engine builder (Erik Koenig at HPE) said he's even seen a HP increase by using the same parts from an aluminum block in an iron because the tolerances are consistent. If you going with FI you'd probably be better off with an iron block but hurry new ones are getting scarce!
Greg
Kane
Old Jan 3, 2005 | 03:28 AM
sr71bbjr's Avatar
and a stock crank but you cant say that it's not on the back of your mind when the boost controller keeps going up
Old Jan 3, 2005 | 03:32 AM
y2khawk's Avatar
There's a real crank going in it now, but still an aluminum block
Old Jan 3, 2005 | 03:41 AM
Arkangel77's Avatar
Y2kHawk - You got 8.299@166.67 & 8.527@170.95 out of a stock Crank and its still holding together? WOW thats Impresive!
Old Jan 3, 2005 | 07:36 AM
BlackCamaroSS02's Avatar
How? lol are they that sturdy? Didnt think the stocker would hold up.
Old Jan 3, 2005 | 04:28 PM
The Guy in MY 99TA's Avatar
I like the aluminum blocks but I personally don't see spending the money to run an aluminum block when you sink all the money into the shortblock and then ya never know when your block COULD split. But that can still be said with a iron block too. I just don't have the money to take the chances with nor the money to do a C5R block either.
Harlan.... I think you got lucky and got a block that was a faulty design and is solid maybe??
Josh S.
Old Jan 3, 2005 | 04:59 PM
WS-Sick's Avatar
I plan on keeping my aluminum block for my turbo. I'm definitely forging the internals though. I may stay with the stock crank for a while though....
Old Jan 3, 2005 | 06:22 PM
NA$TY-TA's Avatar
Were have those 2 guys above been?????????? i guess they dont follow the fastest LS1's that much...........
Matt, Is it still going to be a 348 or is that a suprise also?? ha ha
Kyle
Old Jan 3, 2005 | 06:25 PM
NA$TY-TA's Avatar
Oh and he is also running 6.0L heads, standard head studs and standard GM MLS head gaskets and no O-ringing........ and tuned on a STOCK PCM.
Kyle
Old Jan 3, 2005 | 06:39 PM
I beleive that it is doing it. I just can't say that I beleive the car will stay together for any length of time. I may be wrong but its a chance that I can't afford to take personally.
Josh S.
Old Jan 3, 2005 | 07:02 PM
NA$TY-TA's Avatar
Thats why i went Iron..... that and the fact of when i blew my head gasket it took a chunk of the block with it and ruined the block....
Old Jan 3, 2005 | 07:04 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I saw Matt run like 10+ 8 second passes at NPR, between his TnT'ing and the event. Seemed like the aluminum block worked pretty well.
Old Jan 3, 2005 | 07:27 PM
Arkangel77's Avatar
I only just recently started reading this Forum steadily and I only still read threw it Hit and miss? Sorry if I was behind the Times.
Lata, Ark
Old Jan 3, 2005 | 07:30 PM
mdhmi's Avatar
Matt's car has held together for over two years AFAIK. I have also seen a number of 700 rwhp stock block (forged bottom-end) LS1 Y-Bodies holding up for extended periods of time (none have broken).. Generally after the bottom-end is forged the only thing that breaks is driveline components.
Cheers,
Mark
Old Jan 3, 2005 | 07:38 PM
NA$TY-TA's Avatar
Lata, Ark
no prob.... didnt mean to be harsh.
kyle
