Turbo car smoking LOTS
It was driven under boost like that with stock injectors At idle it would smoke like CRAZY, and it didnt like to restart because the plugs were so oil soaked weird gray tint to them. At this point I was asked to tune it with the 60 injectors that were going in. 02s were FUBARed, and it didnt like to be started, ran fine once running though, so I knew it wasnt a tune thing it was some other issue, that when I pulled plugs, found oil, and for now am running an open loop tune because it kills O2s I temporarily hooked up stock PCV/line like ATI has their kit setup, and 98% of smoke went away and the last %2 may have been because it was 15 degrees outside
After all that oil consumption, wasnt very keen on having any lines pulling from in front of the turbo, so he tried what everyone here recoomend, ran all valve cover ports with 3/8 line to a catch can with breather. At idle you can see crank case vapors from the breather, which is normal, but now under WOT it smokes, which it didnt used to do before. He says it seems like its smoking more and more now. Made ok power 455 hp/460 tq, with smoke rolling out the tailpipes. It fills up the catchcan/breather with a off color liquid guessing its a combination of condensation/oil mist from the valvecover. 5 psi shouldnt need to much to prevent crankcase pressure from building up, but it just doesnt seem like the rings are sealing well or something. Actually pulled the oil level down after a few pulls on the dyno (only made 3 or 4 MAX) but doesnt seem to consume much driving around, although it smokes. He said it seem like it always drops till it hits a certain point or something, could the oil drainback be not working properly and its building up in the turbo, leaking thru turbo until the level is low enough that it drains back properly?
Thinking valve seals, (some heads are known for this) rings, or PCV just not cutting it. Anyway to test these things? Gonna do a quick compression test on a few cylinders, and then leak down on them I guess should be the next step. is there a "blowby gauge" Maybe pull intake off to look at leakage past valve seals? I hope its not a single cylinder problem, plug access is horrible on these things.
power can fool you, my buddy made 550 with a half melted piston!!
plugs covered in oil, sounds like rings. do a leakdown on it, that will rule out the turbo
Sound like good plan of action?: do leakdown, pull inlet hat off, pull intake, if at that point PCV seems to be an issue like breathers arent doing enough, then do LS6 valley cover and let the turbo pull on crankcase with an air/oil separator inline to pull out any remaining oil vapor? The guy already spents lots of dollars, and its been months so far without the car, but now that my hands are in it, I want to ensure as little problems remain as possible. I put a pretty conservative tune in it on the dyno, torque curve was pretty smooth, as it should be for 19 deg timing, 11.5:1 air/fuel at only 5 psi - trying to avoid a problem if it is ingesting oil like I think it is
The turbo was just rebuilt when another shop put it together, due to the oil backing up into it.
Slowly working out all the bugs though
