Help me with my set up
Old Jan 6, 2005 | 03:15 AM
Solobarictahoe's Avatar
Default Help me with my set up
2004 Pontiac GTO Stock will soon have full offroad exhaust. then prochargers HO kit with 7 psi with the P1 blower. the lower end i wanna leave stock. for the heads since i am going to just keep it at 7 psi i wanted to just get a stage three head at the stock compression ratio or just port and polish the stock head. and then use maybe speed inc blower cam and a 78/78 lsx intake will that get me 500 rwhp and will that work.
Since the procharger ho kit works with 10:1 i will leave it 10:1 i will just get a better flowing head and a better cam for the blower. let me know if this is worth it. i know i get around 460 rwhp with the ho kit alone but i wanna boost it up a lil to 500. and that will be enough it will be a daily driver.
Old Jan 6, 2005 | 04:10 AM
goober35's Avatar
If you could drop the CR to 9.5:1 the motor would last longer and it would be safer. You could do this when you get a set of ported heads.
