Ati pulleys
Old Jan 6, 2005 | 10:21 PM
CMKworm's Avatar
Question Ati pulleys
I'm installing the charger, do I have to run the stock harmon. bal. and alt. pulleys with the ati crank? How do I get the crank bolt out with out the pulley spinning? Is the ati crank bolt reusable?
Old Jan 7, 2005 | 03:09 PM
Blown Ta's Avatar
you have to use the stock pulleys, the ati pulley goes in the stock crank pulley, the bolt is not reusable, only use it once. the way i did it i removed the starter and had a friend hold the flywheel with a screwdriver, while i removed the stock crank bolt.
hope this helps
armend
Old Jan 7, 2005 | 03:31 PM
xssive's Avatar
The ATI crank bolt is reuseable, the stock bolt is not.
Red loctite is your friend
