2bar and 3bar GM MAP sensor part numbers?
I want both sensors -- I will be able to write 100% supported 2bar tunes and should be able to write 3bar tunes in some betaware.
1 million thanks in advance!
16235939
Connector keying might be different though.
It's the BARO sensor on the supercharged saturn ION
Think about the power levels involved.
We don't run into problems until you run out of MAF range, usually over 600HP.
Not too many factory cars doing that
I am trying to find out if I have a 1 or 2 bar map sensor. If it is a 1 bar, what do you recommend and where can I get the sensor and plug as well? Thank you all in advance.
Part# 12644228 AC Delco
Bowtie777
