Good Blower Cam
Old Jan 7, 2005 | 08:23 PM
JerikSS's Avatar
Default Good Blower Cam
Do u guys think this is a good blower cam? I am in the market for one and I already have this one, from my brothers car. Will a blower running around 7psi be okay, or is it to big?
230/237 .543/.544 112
Old Jan 8, 2005 | 03:23 AM
MelloYellow's Avatar
Wrong Cam. Don't like the Lobe.
Old Jan 8, 2005 | 09:14 AM
NA$TY-TA's Avatar
Im with mello.... the stock cam would work better then that cam........ the 112 LSA will bleed off to much boost to be even worth installing it. Do a cam on a 114LSA or higher.....
Im a big fan of a 224/230 .580/.590 on a 114LSA...... You can go bigger if you like... Just watch the P to V clearence.
Kyle
Old Jan 8, 2005 | 07:15 PM
JerikSS's Avatar
How many horses will a gain from a gt2-3 compared to stock and the above mentioned cam?
Old Jan 8, 2005 | 09:16 PM
Caveman's Avatar
10 & 11 Second Club
I`m running a Comp 234-240, 5.98/6.08 on 112lsa. The guy I bought the RMCR Ttrim kit from was seeing 11lbs on a stock cam+ motor. On my 382 allbore with this cam I`m getting 10.5lbs. The power is low because of the too loose TP 4400 thats slipping 500-600 rpm and 14* timing +11:1AF, that was to stay safe with my 5 year old ARE heads until the AFR 225s.
