How to identify tial wastegate with calipers?
I have a unknown tial wastegate and I want to figure out what it is, where should I mesure?
The exhaust inlet area is about 39.6mm close to the valve, the od of the exhaust after the vband flange section of the wastegate is 63.40mm
There is a piece that slips out when the flange is not connected, when that is out the ID of the valve area is 46.62mm, when that piece is out i can see through past the valve.
The aluminum housing also says TIAL SPORT and of course has the serial number which does not seem to indicate their part number.
Originally Posted by y2khawk
44's are the only ones with V-band from Tial AFAIK
