Belt Rubbing From Hell!!!!!
So i should make sure they all have the same number of shims. another qeustion, once the belt goes on the blower pulley, it is really close to the j-bracket. should it be that close or should there be some space? if it is not reall close I dont see how adding a shim would make it seperate?
You should get that brace back today, actually!
I'll pm the track # right now just in case...
I'll also ask Scott about the j bracket issue...
give me a few to get some more info and I'll be in touch again one way or anpther!!
wendy
I started the car up and got under neath it to check belt clearence and it is actually pretty good now. I dunno what happened but everything had some room. So i think it was just flexing.
I started the car up and got under neath it to check belt clearence and it is actually pretty good now. I dunno what happened but everything had some room. So i think it was just flexing.Good to here now go drive it and beat on it a little and let us know.
Kyle
I know he did go to the track and no belt problems and the MPH was awsome..... the ET was
He has to fix a shift fork in his tranny so he can really bang some gears
and run a awsome ET. Im sure he will post up later today.Kyle
hopefully i will have some good et's.
hopefully i will have some good et's.Some folks powershift to keep the boost up but that can be tricky and costly.
