stupid idea but would it work?
Old Jan 18, 2005 | 06:17 PM
The Guy in MY 99TA's Avatar
Default stupid idea but would it work?
If I was to build a 408 w/ about 11.8 compression and put boost on it for a MAX effort engine........ its not something that I am going to or want to do I just want to know IF IT WOULD?
Josh S.
Old Jan 18, 2005 | 06:56 PM
Boostaholic's Avatar
I think you might end up with a little preignition and detonation to the point you would fracture or break a rod, i could be wrong though,
Old Jan 18, 2005 | 07:21 PM
TTSSZ's Avatar
Josh S.
The 2800hp Twin Turbo aluminum Pontiac motor (posted a few weeks ago) had 10 to 1.
http://www.highperformancepontiac.co...410pon_butler/
Old Jan 18, 2005 | 07:51 PM
Billy the Great's Avatar
new saleen s7 twin turbo is 11:1 but with only 5.5 psi
Old Jan 18, 2005 | 09:25 PM
so it could happen. I was just wondering b/c I know top fuel cars must have some hella compression and then with the added blower it must be outragous.
Josh S.
Old Jan 18, 2005 | 09:50 PM
slow's Avatar
you said the key word there
TOP FUEL.
Ryan
Old Jan 19, 2005 | 06:03 AM
smokinHawk's Avatar
if you run alchol straight
Old Jan 19, 2005 | 08:38 AM
superr5's Avatar
10 years ago Porsche started upping compression on their motors, running a little less boost.
Old Jan 19, 2005 | 01:51 PM
Spambell's Avatar
Both ways will work. Lower compression - up the boost
or up compression - lower boost.
Just as long as you make sure you have enough fuel.
And pull out timing.
Old Jan 19, 2005 | 02:21 PM
NXRICKY's Avatar
Closed ex-Sponsor Account
I would think the more boost the bigger the band. Or the larger stick of dynomite there is, just me opion.
Ricky
Old Jan 19, 2005 | 08:11 PM
well i'll be spraying this motor but i was just wondering if it could be boosted. I would actually like to boost it one time with a small amount but at that point I'de pull the engine and put different pistons in of coarse.
Being that people run 20+ psi on low compression what do you think would happen with like 10?
Josh S.
