Methanol mix A/F ratio code CRACKED!
Old May 15, 2013 | 10:08 AM
  #61
Sales@Tick's Avatar
What is even more interesting is with my old turbo car Dave(you're very familiar with) I tried MANY different AFR strategies, timing strategies, different methanol to water %, using 100% M1, using 80% M1 and 20% water etc. etc. etc.
What I found at the end of the day was that my car went the fastest mph it's ever been at the boost level I was running it at with a mixture of 85% M1 methanol and 15% water(using proper mathematical conversions) a timing advance of 14* at peak torque and 16* up top and an AFR of 11.8-12.0. This was with 50% C16 and 50% pump 93 in the gas tank as well.
I tried it richer and it slowed down, a lot. I tried 100% M1 and it did well. I also tried 50%/50% M1 to H20, but the highest MPH came when using a little bit of water in there with it.
Old Dec 29, 2013 | 01:43 AM
  #62
crashly's Avatar
Originally Posted by MelloYellow
Ripped from C5 Forum.
Twin Turbo, No I/C, Straight Methanol, 44psi, 10:1, 2900HP.
http://www.highperformancepontiac.co...410pon_butler/
just for data purposes ,for who ever reads this stuff
the bsfc was 1.5 ish
or more like 3.3-3.5 :1 a/f
cheers
Old Dec 29, 2013 | 01:48 AM
  #63
crashly's Avatar
Originally Posted by MIGHTYMOUSE
have seen that, good reading. i think if you are running 100% of either fuel like was said above just keep the lambdaover 1.4 , and if you're using an alcohol scaled meter keep it 3.3-3.5xish.
that is because the bsfc for each is different, when you mix them i 'think' you need to make an adjustment to the target. havent spent any time on it yet.. it will probably come out the same as my first calculator.
fixed
all good, I realize that post was 2005
happy new year, cheers
Old Dec 30, 2013 | 09:56 AM
  #64
bad6as's Avatar
good read
