SC guys, will larger injectors help?
Old Jan 24, 2005 | 12:01 PM
Tapout's Avatar
Question SC guys, will larger injectors help?
I have the 36lbs in right now, I getting ready to do a cam swap, will larger, say 42 lbs injectors make a difference over the 36??
Old Jan 24, 2005 | 12:06 PM
rwb's Avatar
rwb
Yes..
Old Jan 24, 2005 | 12:35 PM
kcshaner's Avatar
Much safer to go bigger....I have a set of DLM (Bosch) 50lbs high impedence for sale. About 200 miles and 7 dyno runs on them. $500 new, will do $300 shipped to your door.
They are to small for my application and want 65 or 72's
Old Jan 24, 2005 | 01:29 PM
LSs1Power's Avatar
Save your self the money and get 60lbs instead of the 42lbs especially if u are going to run a cam and a SC. I maxed out my new 42lbs injectors around 530rwhp and had to sell them and get the 60lbs injectors. Now with 60psi fuel pressure Im running around 70% DC which is where it should be.
Old Jan 24, 2005 | 06:10 PM
Tapout's Avatar
yea I already have the vortech on with 9lbs of boost. Will the inline pump handle the larger injectors or will I need to go to a larger in tank pump as well?
