STS at 8000 ft.
Old Jan 20, 2005 | 09:17 AM
jggarrid's Avatar
Unhappy STS at 8000 ft.
Somebody has an idea or tip of how can I compensate the high altitude (8000 FT) in a system STS @ 5 PSI?
here my car ir realy realy slow...and the boost start at 4200 RPM
Old Jan 20, 2005 | 09:31 AM
Slowhawk's Avatar
LS1Tech Sponsor
Could be a tuning problem or possible air leaks.The elevation wouldn't affect it that much.
Old Jan 20, 2005 | 09:35 AM
jggarrid's Avatar
Allen Nelson helpme for the tuning and in Texas work great. And no leaks.
Old Jan 20, 2005 | 09:54 AM
jggarrid's Avatar
mmm...I just remember this:
Is an oil leak at the back of the intake close to the block (I think, not sure), here is a pic take it when I changed the clutch. The oil start to leaking about 2 days after the STS install and after a couple of really hard runs. May be a seal broken?
Can this be the cause the poor performance in my car?...I don’t have any idea about this problem.
Help please.
Sorry my English, saludos desde Mexico City
Old Jan 20, 2005 | 12:30 PM
red ws6 99's Avatar
Even if you dont have any leaks, 5 psi at 5800 ft equates to about the same power you would make with 1-1.5 psi at sea level. So probably the car feels slower than it did pre turbo. Yes the spool is going be affected as well. You would need to crank the boost a lot higher to see any noticable gain.
Gary
Old Jan 20, 2005 | 12:40 PM
My84Z's Avatar
take a rd trip a couple hours lol
Old Jan 20, 2005 | 12:44 PM
mongse's Avatar
I ruin the end of films...
For a second, I thought someone put a rear mount on a Cessna.
Altitude has a big effect on ANY engine, not just a turbo one.
Old Jan 20, 2005 | 12:48 PM
dynedta's Avatar
chronic masturbator
how is your pcv system ran? maybe the oil is coming from the knock sensor orings under the intake. Looks exactly like how mine was when I blew mine, I didnt see a performance change but I would change them asap.
Old Jan 20, 2005 | 12:54 PM
LSONE's Avatar
so you got it tuned in texas, and now you're driving it at altitude? get it tuned at altitude
Old Jan 20, 2005 | 01:00 PM
jggarrid's Avatar
Originally Posted by mongse
For a second, I thought someone put a rear mount on a Cessna. .
I don't know if I must cry or laught... ha ha ha
And 5psi at 5500ft = 1.5psi !!!! whow!!!
I hope my GT60-I works fine using more boost and the lag don't go to high
Old Jan 24, 2005 | 04:13 PM
Silver02Z28's Avatar
I second dynedta's comment. I blew oil out my knock sensor o-rings when I blew boost through my PCV. Does STS use a check valve? I'll bet your boosting your crank case.
Old Jan 24, 2005 | 05:53 PM
trtturbo's Avatar
he is not boosting the crank case. There is a check valve on the car so that at 1psi, it will shut the valve and not let the boost into the crank case. He is at 8000ft elevation in Mexico, so there will not be alot of tuning options. Alex, let me know if you want to try a different wastegate spring or boost controller. You will need the fmic before you turn it up.
Old Jan 24, 2005 | 06:20 PM
jggarrid's Avatar
Thank you trtturbo, I'll send you a E-mail
Old Jan 24, 2005 | 07:13 PM
GrannySShifting's Avatar
Build a higher compression motor
