Few Pics of my car's Turbo kit
Originally Posted by andy98Z
Yea I would assume it has to go on the driver side relocated to the top of the engine.
Judging from the pics, I'm assuming you're I/C piping will be in the way on the passenger side.
Originally Posted by NA$TY-TA
Good lookin kit... Any more pics of the kit???? If so send them to me...... in there full size... i have 40G to hold crap....
My email is itlxlr8@hotmail.com
Can you post up some more info on the kit... what size in the downpipe?? How big is the cam?
Kyle
edit.. one more thing what size injectors did you go with??
Kyle
Downpipe is only 3.5in. Not sure on the cam forgot what Chris told me it was. Its a 415ci now 8.7-1 I believe. Alum block ls6 heads, so we'll see.
Power I would like to make over 1000rwhp. But if it doesnt I still have an ET goal in mind.
Why did you reduce the size of the downpipe?? Id have left it the 4" or 5" or whatever it is coming out of the turbine unless you are just overly concerned with it exiting out of the back of the car. thats a pretty big turbo plus you have the IC in the car so I figured a dumped downpipe wouldnt be such a big deal either.
Looks good though! They do good work.
Originally Posted by Tim @ EADPerformance
3.5" was the biggest that would fit between the motor and motor mount stand off. The 3.5" was even clearanced quite a bit to get it to fit correctly in between there.
not everybody can have a fat downpipe
Very nice but hard to "hind" at the races. Yeah I don't know where you are mounting the alternator and powersteering pump?
I/C is inside the car so no real problem with pipeing there Why didn't you mount the I/C out side the car in the noise,there is tons of room and is easyer to do the water to air I/C. No better to mount it in the car?
#33
Good to see some more pics....... What K-member is that?? I ordered the BMR yesterday so we can run my 3.5" downpipe also........ but im only going with a T-88.....
Kyle
Kyle
#34
Kyle
Kyle
#39
It's a standard BMR K-Member. To get the 3.5 dp to fit, they had to cut the motor mount stand off, and weld in a 1" bar straight up, then another bar off that at a 90* to the motor mount.
very strange, the TTIrace kit gets a 3.5" DP in there without cutting rewelding, did you put any bends in the DP?
#40
Kyle
Kyle
