What Boost Controller should I use???
Old Jan 26, 2005 | 04:29 PM
Shinobi'sZ's Avatar
Default What Boost Controller should I use???
I want to use a very simple boost controller. I don't need some fancy digital/analog thing to look at or measure hp and boost. What I need is just something I can throw a switch on and it has a preset amount of boost. Lets say I have 9lb waste gate springs and I want a setting that gives me 14-15lbs. I would like to be able to just flip a switch..doesn't even have to be in the cabin..could be under the hood. But I need something that is reliable, performs good, and isn't very expensive...that sounds like a lot to ask huh
Thanks
Old Jan 26, 2005 | 06:13 PM
quicksilverado's Avatar
STS sells a dual stage boost controller for 150.00 bucks.
Old Jan 27, 2005 | 06:50 AM
Jammer's Avatar
Research the JoeP controller...cheap and easy.
Old Jan 27, 2005 | 11:57 AM
stevieturbo's Avatar
A simple bleed valve is the easiest and cheapest.
Or attach a small in-line solenoid to an air bleed. Size of air bleed will dictate boost level. Solenoid can be switched from inside cabin.
Old Jan 27, 2005 | 12:24 PM
red ws6 99's Avatar
I have posted many times the manual boost controller I use. It a boost block type (my design). It blocks the boost signal from the actuator. It has the following benefits:
1. Since it does not bleed the boost signal you get the fastest spool possible. It build boost slightly faster with just the actuator.
2. Its not affected by load or altitude like a bleed setup.
3. Its cheap and works with all actuators, even actuators with only a single sense line. You need a check valve inline with adjustable relief valve (or back pressure regulator). The relief has to be the pop type (i.e. it does not open until the crack pressure). About $50 for both the relief valve and check valve, plus various fittings.
4. Due to the relief valve and check valve inline the boost will not spike.
The setup could be adapted to an on/off operation by bypassing the controller. I will have to post a schematic with the part numbers again.
Gary
Old Jan 27, 2005 | 04:15 PM
Shinobi'sZ's Avatar
First thanks for the responses.
I like all the ideas. The one that I have found so far that looks very promising..for about $150 shipped..is the STS Boost Controller..from 0-15psi. Electric Dual Solinoid. Does anybody know anything about the STS Boost Controller?????
Gary if you had more information on your product, that would be cool.
Thanks
Old Jan 27, 2005 | 05:47 PM
Talk to Billy at TRTurbo. He can answer any questions you have.
Old Jan 27, 2005 | 06:06 PM
Turbosmart, and Dawes do simple block/bleed devices. No doubt there are plenty of other makers.
Old Jan 27, 2005 | 06:56 PM
RedHardSupra's Avatar
get a used HKS EVC 3 from ebay, very cheap, no frills, gets the job done.
Old Jan 27, 2005 | 07:12 PM
Hennytime's Avatar
i like the greddy unit, its electronic and you can present two boost settings, high and low, and i think it has dual boost solinoids, pretty good incase one breaks, and i think it goes all the way up to 26-30psi
Old Jan 27, 2005 | 07:30 PM
red ws6 99's Avatar
Yeah my setup is just like the dawes hybrid but works with actuators with a single sense port like Incon used. The boost levels can be adjusted with a ****. My setup is not for sale, I don't make them. I will give out the schematic and part numbers so anybody can make them. I will post some stuff tomorrow.
Gary
Old Jan 28, 2005 | 07:50 AM
There are loads of used boost controllers on ebay. Id spend that little bit extra and buy an ebc, once installed, they are so handy to work with in-car.
