absolute most power on pump gas? max boost or a small shot?
Old Jan 31, 2005 | 04:14 PM
parish8's Avatar
single digit dreamer
Default absolute most power on pump gas? max boost or a small shot?
i am looking to absolutly maximize my pump gas hp. i can not use alkey injecton but i can use nitrous or water injection. i just sent in my application to the hotrod pump gas drags and am geting ahead of myself i know but thats how i am. the fuel is 93octane
i have some plans, better flowing header and exhaust are on top of my list but other than that i think i need to maximize my tune.
i have made about 30gtech runs in the last few days and figured out a prety good mix of boost/fuel and timing to get 0KR and nice power. now i am looking at tosing nitrous into the mix too. would pulling 1lb of boost and running a 35shot give me more knock free power or is boost only the way to fly. this will be a dry shot with the injectors adding the extra fuel. anyone have any experience or oponions here.
Old Feb 2, 2005 | 04:32 PM
860 Performance's Avatar
I have lots of exp with N20 & boost, check out the sig.
I love the combo, go for it.
Old Feb 2, 2005 | 04:40 PM
parish8's Avatar
soo, assuming i have a decent intercooler and a properly sized turbo. what will make the most power on pump? maximizing the boost only tune or a tune with a small/moderate shot.
Old Feb 2, 2005 | 04:58 PM
MIGHTYMOUSE's Avatar
you need to get rid of all that exhaust backpressure.. that is really going to help against detonation
Old Feb 2, 2005 | 05:03 PM
strokedls1's Avatar
I saw a mustang guy spray 75 shot through the intercooler and into the air filter. It worked well for him. Cool setup.
Old Feb 2, 2005 | 05:04 PM
parish8's Avatar
you can bet i am working on that. a new header that doesnt merge the banks till it gets to the turbo. better placement of the WG and at least a 3.5"down pipe are all in the works.
with that i think i will need bigger injectors and i think i am going to try some alcohol injection too but i can't use that at the pump gas drags if they happen to invite me.
Old Feb 2, 2005 | 05:06 PM
parish8's Avatar
how do you like this?
Old Feb 2, 2005 | 05:21 PM
qqwqeqwrqwqtq's Avatar
Other than endless drivetrain related variables, it would help if you had something that was a few thousand pounds lighter.
Also, I would test with the fuel they use (rocket brand), rather than your local pump 93.
Old Feb 2, 2005 | 06:15 PM
Keith's Avatar
Ooooooh la la
Bitchin!
Old Feb 2, 2005 | 06:23 PM
parish8's Avatar
that would be sweet, i wonder where i could buy that. i would need an entire drum or maybe more to really dial it in. i am running 92octane here so there may be more power to be had with the 93.
Old Feb 2, 2005 | 06:41 PM
MT POKT's Avatar
I could be looking at this wrong, but I think if it were me, I would switch to a wet shot, maybe 100-125 if the motor will take it maybe even on a progressive controller. If you take the dry shot out of the equation, you have less variables. You don't have to count on the MAF to adjust fuel. W/ boost being progressive, it sounds like a nightmare to tune. Use the wet shot, then your turbo tune would be a constant dependent on MAP, and you'll tune the n2o a little rich w/ jets. Seems to me like the sky's the limit...or the bank account. I plan on a similar set up next year. Big single turbo and a wet shot. Good luck getting in the drags!!
I have no experience with this, just a little brainstorming.
Old Feb 2, 2005 | 07:35 PM
parish8's Avatar
i dont use the maf for anything. i will probably pull it out soon. megasquirt has the ability to add fuel for nitrous. you just tell it how much fuel to add with the injectors. seems like a killer set up to me.
Old Feb 2, 2005 | 07:51 PM
MT POKT's Avatar
I forgot, Chris did tell me you were running the megasquirt. I think I would still run the n2o independently. I don't know much about the megasquirt, but it seems like you would have to run the n2o all the time or constantly change programming. I'm assuming you're using 2 or 3 bar MAP to tune from. Since there are no sensors picking up the n2o I don't see how the computer will adjust for it and know if it's there or not. Good luck w/ it Parish! Hopefully we'll make another trip out to Omaha this year and see the truck in action!
Old Feb 2, 2005 | 07:57 PM
parish8's Avatar
mega kicks *** man. it has a nitrous output and input. it works like this.
built in window switch, coolant temp switch, map switch. so you can select exactly when you want the nitrous output to come on.
then once the nitrous comes on you return a nitrous input signal to the mega and at that point it will add fuel. you can have it switch over to a 2nd ve table and timing table or just have it add a specified amount of fuel, something like in interpolated amount of pulse width added based on rpm.
Old Feb 2, 2005 | 08:01 PM
Yellowsierra's Avatar
Paris how much compression does your motor have? It seems to me you could run more timing or more boost before you see kr but I guess you would know sence you have all the equipment.
Old Feb 2, 2005 | 08:05 PM
parish8's Avatar
about 8.8-1. i have a lot of exhaust presure so that is probably hurting me, not sure. how much boost/timing should i be able to run knock free with an 8.8-1 408?
Old Feb 2, 2005 | 08:13 PM
If you are looking for max HP the combo seems to work well.
One thing that I don't like about it is (on my set-up anyway), is that my supercharger, all of the plumbing, belt, and brackets add up to a lot of weight in front of the front wheels. I truly beieve that I could probably turn a quicker e.t if I switched to just nitrous, because of the weight savings.
I also run the dry shot through my Accel DFI and love it, its real easy to tune plus no lean spike upon activation.
i know my set-up is a little different than yours, but just throwing it out there.
Old Feb 2, 2005 | 09:35 PM
Slowhawk's Avatar
LS1Tech Sponsor
8.8-1 compression could hold alot of boost but it really depends one the Heads,Cam,Turbo size,inlet temp, and of course exhaust backpressure.
For comparison we run a 9.5-1 compression 346 with patriot heads,226cam and STS T70 at 14lbs of boost on pump gas.I run lower timing than people post here,so maybe that is the trick. I know my GN loves the timing low and rich A/F to help it spool faster.18lbs on the street
Old Feb 2, 2005 | 09:50 PM
parish8's Avatar
you run 14psi on pump with no alcohol? how much timing?
i expect the new header,down pipe and exhaust to help a lot.
Old Feb 2, 2005 | 10:47 PM
Slowhawk's Avatar
LS1Tech Sponsor
I think we were at 12 degree's of timing at spoolup and 14 degree's up top with A/F at 10.5-1 at spool and 11-1 the rest. No KR was present.
Also tried higher timing but it spooled slow and didn't make any more power but did KR alittle.
Only 93 octain pump gas,street driven/tuned
