attn. procharger guys....
Old Feb 2, 2005 | 05:11 PM
ss01layinwheel's Avatar
Default attn. procharger guys....
what kind of power are you making and what times are you running on stock long block and cam? Also when do you hit boost at? any other info of any importance that you can think of would be greatly appreciated. thanks alot guys.
Old Feb 2, 2005 | 07:58 PM
LSs1Power's Avatar
Im running a D-1SC pushing 8psi, but i also have a mild Cam. Anyways the Mcloed clutch didnt hold up when i took the car to the track. It was slipping bad in 3rd and 4th, but it still managed 123mph in traps moving a 3800lbs car. There is 125-128mph in it. It should run low 11's on radials or high 10's on ET Streets.
Old Feb 2, 2005 | 10:17 PM
Bryan Wilkinson's Avatar
Today 822RWHP Pump Gas Have not run the car with this power
and for Pro Stock John by 2/11 I will have 900RWHP same pump gas
or really really close
by 2/28 if the heads are ready, 1000RWHP plus same pump gas boost comes on about 2500 RPM
What kind of info are you looking for.
Old Feb 3, 2005 | 01:53 AM
BudH's Avatar
See sig!
When it hit it, I immediately see about 6 lbs of boost! 9 - 10 very soon after that!
Old Feb 3, 2005 | 02:26 AM
SL0WNESS's Avatar
what size crank pulley are you guys running that you are seeing so much boost instantly?
Old Feb 3, 2005 | 02:44 AM
LSs1Power's Avatar
Im running 7.65 crank now with 4.25 blower pulley. I see 3psi at 2000RPM and 5psi at 3000 RPM. My car is pullied for 8psi at 6200-6400RPM. I just got a 8.5 crank pulley im going to try really soon with alky injection to keep things safe on the stock bottom end.
Old Feb 3, 2005 | 02:49 AM
SL0WNESS's Avatar
Nice. I see about the same amount of boost you do by 3000rpm with my S-trim, with a 2.75 blower & 6.87 crank, and 11+ by 5800rpm.
Old Feb 3, 2005 | 01:26 PM
BudH's Avatar
Stock crank pulley and a 3.4 SC pulley!
Approx 3200 stall converter! I never see 2 - 3000 rpm at WOT. In about an instant, I'm at 4 - 4500 and climbing rapidly! That's why the boost is almost instantaneous.
Old Feb 3, 2005 | 07:09 PM
I'm lookin at all my options(supercharger or turbo), i was going to get a turbo kit, but they are over price and wwwaaayyy to much of a pain to install(even though i have the meens to do it myself). it just seems that its not worth the hasstle to do turbo when you can get just about all the same results from a blower. thanks for all the help fellas.
