Putting a fan on a fmic
http://store.summitracing.com/defaul...4839058+300458
If you put a WOT switch on the TB and then hooked it up to a relay, you wouldnt have to worry about drawing extra amps at idle, theyd only kick on while you were producing boost at WOT.
Billy
I think everyone is getting confused between the BUMPER and the BUMPER COVER. I am definitly going to cut up the BUMPER, but do not want to cut a big nasty hole in my BUMPER COVER. And so far you all are right with what you are saying. Just need to use the right situation. Thanks
Ok, I feel better knowing you're not crazy afterall.
Also if you intercooler is not in the front in direct air flow you have to get air to some how. Either with a fan, or fan and scoop combo.
And when you are realy on the boost and want to keep the air/air intercooler, add water meth, or spray CO2 across you intercooler.
Ricky
There has been a production car that used a fan to help pull air through the intercooler, that car was the Grand National. The fan was directly mounted to the crank pulley and was directly behind the IC, without a shroud from what I can remember. I believe a good front mount setup would be better than the use of a fan. I'm just saying it was done and it works.
Jeff
Jeff
-Geoff
