wonderin about a cam
Old Feb 10, 2005 | 07:30 PM
cowboys z28's Avatar
Default wonderin about a cam
i have a mostly stock ls1 and am getting a head and cam package for it. i eventually am gonna supercharge it. i was wondering what would be a get head and cam to ride around on before and after i charge it because i really don't want to put one in now and then have to change it out for a different setup after i charge it. i'm planning on a 8psi procharger with twin intercoolers. any advice would be appreciated
Old Feb 10, 2005 | 09:17 PM
http://www.lingenfelter.com/lingenfe...=7&pf%5Fid=690
this is the cam and head package i had in mind
Old Feb 10, 2005 | 11:59 PM
ls1 1990 VN's Avatar
Standed or Blower cam
Old Feb 11, 2005 | 12:46 AM
LSs1Power's Avatar
That is exactly what i did.... I got the FM7 cam which made great power N/A and then i added the Procharger. Don't waste your money on heads now. Just get the cam and u will be happy with it for a while. Good luck.
Old Feb 11, 2005 | 09:42 AM
appreciate the advice guys. thank you
Old Feb 11, 2005 | 10:29 AM
Fast Toys Performance Parts's Avatar
Default Cam
As mentioned, check out the Ligenfelter GT2-3 cam we sell. This is a great blower cam and will not bleed off any boost. This is the same cam Ligenfelter uses in the blistering twin turbo setups!
Old Feb 11, 2005 | 11:58 AM
DanZ28's Avatar
This cam is good for both blower and turbo setup's?
If your gonna do heads, would 6.0L heads be a better choice by lowering the compression?
Dan
Old Feb 11, 2005 | 12:22 PM
Dan
Yes that cam works great for blower or turbo setups. If you want to run more boost, lowering the compression is definitely a good idea!
Old Feb 14, 2005 | 12:50 PM
I was planning on putting the supercharger up there and then when my motor blew, just get a low compression engine built and put the supercharger on that one. because I know I can't do but so much with a stock bottom end. Lol. Just a matter of time. This supercharger is a 8-lb with d-1sc and twin intercoolers. It's rated at 150+ hp so I'll be happy with a 100 hp increase. I'm not tryin to do anything crazy... I'm aiming for a 600-650 hp when I'm finished (If there's such a thing as being finished)
