How much boost are the stock rods good for?
Old Feb 11, 2005 | 02:30 PM
Got Me SOM's Avatar
Default How much boost are the stock rods good for?
Just curious if I bought a block with stock rods, ARP rod bolts and forged pistons how much power can that hold safely?
Money's tight right now and I need a shortblock . Thanks
Old Feb 11, 2005 | 02:38 PM
cablebandit's Avatar
Stock rods have yet to fail at a hp level. As long as you change stock bolts to arps, you should be fine. I have always run stock rods with 600-700rwhp. Harlan ran them at 600+ for many miles. Mike Brown ran like 9.89 and 700rwhp with them. Because boost keeps some pressure on the pistons most of the time (boost or exhaust back pressure) rods go a lot further on a boost motor vs a nitrous motor or even N/A.
Old Feb 11, 2005 | 02:43 PM
Got Me SOM's Avatar
cool.
Old Feb 11, 2005 | 02:55 PM
NA$TY-TA's Avatar
Yep ill agree..... stock rods will go quite a long way...... just be sure you use a set of ARP rod bolts and a good set of File fit rings and you should be fine....... What compression??
Kyle
Old Feb 11, 2005 | 03:24 PM
Fullthrottledan1
Guest
Posts: n/a
thats what i want to hear!
Old Feb 11, 2005 | 03:27 PM
Got Me SOM's Avatar
I'd like to run as close to 9:1 as possible and run 12 lbs on pump gas safely. I don't know if that will be feasible with my heads.
Let me ask this if the stock rods are that strong why bother upgrading to forged rods?
Old Feb 11, 2005 | 03:32 PM
NA$TY-TA's Avatar
Me myself i wouldnt push them far over 650rwhp..... and with after market ones you can go alot farther....... and the BIG ONE in my book......................... Piece of mind .........
Kyle
Old Feb 11, 2005 | 03:38 PM
Got Me SOM's Avatar
10/4 on that. ok cool something to think about. I dont think I'll ever get to power level unless I start shitting money, LOL.
Old Feb 12, 2005 | 05:12 PM
84camaroturbo's Avatar
my turbo spiked 30+ pounds then lifted the head filled the cylander with water blew the cylander wall out but didnt hurt the rod. if you polish the rod and take out all the casting marks and sharp edges the will hold more power.
