Where to buy Dished pistons
Old Feb 18, 2005 | 11:54 AM
BRENTT94Z's Avatar
Default Where to buy Dished pistons
Where do I find some Dished pistons that will lower my compression to 9:1
or even 9.5:1 on the LT1?
Or what are my other options to lowering my compression?
I have a Vortech V1 s trim and want to run 6-7psi.
Im guessing Im somewhere around 11:1
SPECS:
58cc heads on ROSS flat top pistons, 383, heads have been milled .008
Im using cometic head gaskets .057 thickness.
How do I figure my exact compression?
Please Help.
Thanks
Old Feb 18, 2005 | 01:08 PM
eviltwins's Avatar
Flat tops in a 383 with 58CC heads, and a .057 gasket are anywhere from about 11.2:1-11.6:1, depending on how far in the hole the pistons are. What length of rod are you using? JE makes some off the shelf 383 blower pistons that will knock you down to around 8.8:1 with a 6" rod or 8.5:1 with a 5.7" rod.
Old Feb 18, 2005 | 01:14 PM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
Give us a call and we can get you into a Diamond off the shelf piston. Here's our number, 586-954-3181
Thanks
Old Feb 18, 2005 | 01:22 PM
BRENTT94Z's Avatar
Rods are 5.7
Old Feb 19, 2005 | 09:42 AM
BRENTT94Z's Avatar
Still looking.
Apperantly Diamond doesnt have an application for dished pistons w/ a 4.030 bore, 3.75 stroke, 5.7 rods.?????
Please Help!
Old Feb 19, 2005 | 05:04 PM
eviltwins's Avatar
Originally Posted by BRENTT94Z
Still looking.
Please Help!
I noticed that too. I guess JE is the only off the shelf maker. You could have Diamond make you a custom piston though.
