finally working on my sts install
Old Feb 23, 2005 | 02:49 PM
Blackbird's Avatar
I hear ya Zombie, mine is datalogged everytime I go out.
I use efilive and it has alarms you can set so if the computer ever registers knock the laptop screams and I get off the gas. That and my ear is definetly trained to listen for it.
Your a bad influence now you have me thinking oh what the heck just run 10psi, it will be just fine...............
Old Feb 23, 2005 | 03:02 PM
GR33N GoblinM6's Avatar
Blackbird, what is that pump next to the intercooler pumping? what fluid is running in it? also is that a ShurFlo pump?
Old Feb 23, 2005 | 03:03 PM
NA$TY-TA's Avatar
Originally Posted by Blackbird
it's metalcast paint by dupont I think it is.
they have a red, blue, green, and yellow if I remember correctly.
i got it at my local kragen auto parts.
once everything is all setup I will remove the pipes and give them another coat to fix all the scratches I am putting in them then coat with clear and hope they hold up ok.
green..
iLL BE LOOKING FOR IT....
Kyle
Old Feb 23, 2005 | 03:09 PM
Blackbird's Avatar
That is the pump for the water/alky injection. It will be pumping a water/alky mix in high boost situations to suppliment the lovely 91 octane gas we get to use here in California.
Kyle - yah the green they have will match your car nicely.
OldBlue - install is going fine. it's all pretty straight forward. if i was just installing the base kit unmodified it would have taken a day. but i have been adding and modifying things left and right so that has definetely increased the install time.
Old Feb 23, 2005 | 07:47 PM
Silver02Z28's Avatar
Nice install. Let us know how it runs!
Anything over 500rwhp and I am happy.
Getting older and having a baby mellows out ones HP goals
Don't worry, once they get a little older, the HP bug comes back as strong as ever.
Old Feb 23, 2005 | 09:35 PM
highspeedspecialist's Avatar
hey blackbird I'm in the bayarea too and would like to see the car once done...Anyways are you going to leave it single tip?
Old Feb 24, 2005 | 09:37 AM
Blackbird's Avatar
no, two tips. one for the exhaust and the other side I am going to plumb the wastegate into. I am using supertrapp mufflers for the tips. I want to muffle the wastegate sound as that is the one thing I hate about the STS. under boost all you hear is pshhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh. I want to hear whistle and exhaust and no pshhhhhhhhhhhhhhhhhhhhhhh.
Old Feb 24, 2005 | 08:09 PM
oh ok
