Twin Turbo tuning question?
Any help would be appreciated.
Are you actually in boost at the point it rattles?
What's the fuel doing?
I tried pulling timing until it was negative. -4. Yes it is just barely into the boost when it rattles,pops, etc. It reads knock retard before it hits boost-low vacuum. it reads knock when let off also.
The fuel pressure is at 52 to 56 psi. He has a fuel pressure regulator that increases fuel pressure with boost.
I highly doubt it detonating with the advange that low, unless you're not getting the correct advance or the A/F is extremely lean.
have you verified the delivered advance with a timing light?
Put a wideband in it?
the long term and short term fuel trims show rich. I have not put a wideband on it or a timing light.
I don't know if I can duplicate it on the dyno with the sniffer. But I guess I can give it a try.
The owner says he has the vacuum line for the waste gates hooked up to the manifold after the throttle body. He is wondering if at part throttle the turbos are spooling up and getting higher boost pressure in the inlet ductwork while the throttle is only partially cracked. Creating high inlet temperatures.??
What's done to the motor??
I'm reading the advance and knock retard with a scanner. The knock retard reduces the timing down to the low octane table. Then I start getting detonation. How else could I verify the timing while driving down the road other then using a scanner?
I do appreciate your help.
have you adjusted the low octane tables, making sure for some odd reason the timing in those are lower then the high octane tables?
KR has a limit to how much it pulls. That's not the same thing as the low table.
What's the low table look like compared to the high table?
No advance ground in.
The low octane table is 12 degrees lower then the high octane.
Also from talking to the owner of the truck over the weekend he said when he started the project he bought a book that was written by some turbo expert (cannot remember who). In the book it said that pulling timing out make turbo cars run alot hotter. Does this sound right?
