headers with turbocharger?
Old Feb 24, 2005 | 08:52 PM
TransAmDude00's Avatar
Default headers with turbocharger?
I'm tryin to figure out if you get better gains running LTs or not with turbo systems? I think I read that with STS its better to run the stock manifolds? Does this apply to all systems or just STS because of the rear mounting?
Thanks
Old Feb 24, 2005 | 08:58 PM
sb427f-car's Avatar
SSU'S Vice Mod
You'd be better off to run LTs. The more exhaust you can move to the turbo, the better it'll spool
Old Feb 25, 2005 | 01:03 AM
F8L Z71's Avatar
12 Second Truck Club
This is debatable since there is a ton of backpressure in that exhaust system with the small A/R that the STS kits run. So much so that a header may not make any difference and depending on design you could lose prescious heat which obviously helps spool also. On a large HP and large turbo (and A/R) car I would probably agree with this but there are a lot of variables no? For what it's worth I have not seen any sizable gains with actual proof yet.
On a front mount kit you can't simply run "headers" . Half of a front mount kit is the special manifolds that mate up to the turbo so your question really isn't applicable to those types of systems if I read your question right.
Old Feb 25, 2005 | 07:17 AM
sb427f-car's Avatar
SSU'S Vice Mod
I didn't even think about that kit being pretty much a slap on deal and go. You're right in that @ somepoint you would be to big and not have any distinct advantage in that due to the heat loss, even though you'd be "flowing" more. But I guess that comes back to our laws of theromdynamics in that faster gas has more heat so yeah, there is a fine line between how much you can flow and the energy needed to spool the turbo that far down the line. Guess that's what happens when you've got a cold, on meds, and tired.
Old Feb 25, 2005 | 09:02 AM
disassembled's Avatar
excuses, excuses..............
Greg
