Air compressor and some hose= Major cheap HP?
Wouldn't this work? Why pay oodles for FI set-ups when you can tap and thread an air hose and run your air compressor to create boost.
What's your thoughts?
Cost to me would be $12 sprinkler valve, wiring, a WOT switch and some thread/barbed fittings.
Philip S.
Philip S.
). Anyways he gained an avg of 2mph(20HP) in the 1/4mile by turning the bottle open from behind the seat LOL, but that was it. I wouldn't be comparing an air compressor to a SC or Turbo which flows over 1200 CFM in most cases. Anyone can tell us what does 150psi of compressed air translate in CFM? I hope its over 550cfm at the least to see some gains. Philip S.
Philip S.
Ryan
(and to think us import guys get our ***** busted
Philip S.
Philip S.
Man the pressure coming out of the air compressor won't give u more than 20HP because i have seen someone who did it before and we did measure the gains. I dont think u will lean the car with an air compressor. As i said before you might see 10-20HP gain with a really high pressure air compressor or bottle and thats it. Don't expect anything more and again don't compare it to real Forced Induction.
A good 80 gallon air compressor will flow around 28 cfm at 90 psi, less than that at 150 psi. Good luck using that to feed your motor.
On a better note...keep thinking outside the box....that's where great ideas transform into technology!
Good luck with your efforts!
Philip S.
But please, do not let me, a trained tech, keep you from screwing up your truck. I love making money off people like you. See you soon.
I heard the problem with running pure oxygen is that it burns way too hot and that it is pretty volatile, but if you could get away with it your bottle would last way longer
