Phamspeed kit installed!!!!
Old Feb 27, 2005 | 04:26 PM
  #41
HellRaiser's Avatar
Originally Posted by Armageddon
I'm about to go test fit that bumper on the intercooler. I'll snag some pics while I'm up at the shop. I have high hopes for this kit, I know for a fact it'll max out the little T70 I'm running right now real quick with my built Iron Block. If I didnt already have the turbo and wastegate from my old STS kit I would have jumped all over his whole GT42 kit in a heartbeat. I wish I had waited just a litte longer Lesson learned I guess.
Someone here said he saw the T70 put down 750rwhp. If I max out at that then I would be one happy ****!!!
Old Feb 27, 2005 | 04:29 PM
  #42
BIGBOS's Avatar
Sounds like the kit is going well so far.....get some pics up
Old Feb 27, 2005 | 08:24 PM
  #43
NA$TY-TA's Avatar
Cool when will the pics be up??????
Kyle
Old Feb 27, 2005 | 08:35 PM
  #44
frcefed98's Avatar
keep the good news coming
J
Old Feb 27, 2005 | 09:10 PM
  #45
FormulaFire's Avatar
How much did you pay for Everything total?
Old Feb 27, 2005 | 10:55 PM
  #46
frcefed98's Avatar
Originally Posted by sscam68
Who was this "guru"
Dickson, he misunderstood me. He made a quick call to HP today to verify that this is the right turbo for me......if i were to go this way
Old Feb 28, 2005 | 12:21 AM
  #47
Armageddon's Avatar
...with cheese.
I just spent a couple hours building the intercooler piping and working on the fuel system.
I took a bunch of pics before it got dark for you guys to have a look at.
Heres a pic of the wastegate under the car, this is without the air dam http://server2.uploadit.org/files/Ar...-Wastegate.jpg
Heres where the turbo sits... it's almost impossible to see it from the top.
Can you say sleeper? ... nah I just relocated my radiator to the front and I've got a bad vacuum leak with a cold air induction setup.
http://server3.uploadit.org/files/Armageddon-Turbo.jpg
Here is my old STS exhaust... lol
BTW, anybody need a STS oil pump and wiring harness?
http://server3.uploadit.org/files/Armageddon-STS.jpg
Heres a pic of the spring bracket he made just to shut me up about pipe integrity
This spring bolts to the back A/C Compressor bracket bolt. Its just a little reasurrance
http://server2.uploadit.org/files/Armageddon-Spring.jpg
This is a pic of the top of the engine bay with the new fans mounted. This pic was taken without the bracket that goes on top and holds it all. It's the bracket that came with the K&N FIPK kit. Modified slightly. You cant see anything!
http://server2.uploadit.org/files/Armageddon-Side.jpg
Heres a random pic I took of my 9in Moser and my Sumped Aluminum tank.
http://server2.uploadit.org/files/Armageddon-Rear.jpg
Quick shot of the passenger side manifold. Showing how it fits in there perfectly.
http://server3.uploadit.org/files/Ar...erManifold.jpg
I cut my bumper and test fit the intercooler tonight. Heres a rough pic of what it's going to look like finished.
http://server3.uploadit.org/files/Ar...ntercooler.jpg
Man, I still can't believe how great these fans fit in there. Like a glove!
http://server2.uploadit.org/files/Armageddon-Fans.jpg
More fans...
http://server3.uploadit.org/files/Armageddon-Fans1.jpg
Heres the driver side manifold. Plenty of clearance from the steering shaft.
http://server2.uploadit.org/files/Ar...erManifold.jpg
Here is under the car, I just mounted the 02 sensors.
http://server3.uploadit.org/files/Armageddon-02.jpg
Here's my baby... Just waiting to be let loose
http://server2.uploadit.org/files/Armageddon-Car.jpg
Old Feb 28, 2005 | 12:34 AM
  #48
BIGBOS's Avatar
Man thats looks like a really good kit, now get some dyno tuning done w/it
How much boost do you plan on running?
Old Feb 28, 2005 | 12:38 AM
  #49
Armageddon's Avatar
...with cheese.
The most that turbo can handle... and when I max it out, I'm sticking a PTE88 in there. That motor is built for boost, and lots of it.
Old Feb 28, 2005 | 12:42 AM
  #50
BIGBOS's Avatar
Good to hear
Old Feb 28, 2005 | 12:44 AM
  #51
Sandmann120's Avatar
Sweet setup. I'm glad that somebody is finally putting the Phamspeed kit to good use. I hope to use mine on the stock shortblock, at least for a little while. Probably with a set of ported 6.0 heads. Any pics yet of intercooler plumbing? Again, it looks very nice.
Old Feb 28, 2005 | 04:44 AM
  #52
slyws6's Avatar
looks good man, let us know how it dyno's!
-Sly
Old Feb 28, 2005 | 08:13 AM
  #53
Tiago's Avatar
looks good
Old Feb 28, 2005 | 09:52 AM
  #54
abadss's Avatar
the setup looks very well done, i am glad you got some pics up for people to see this kit. i think this is the one i am leaning towards when i get the money. cant wait to see some dyno #'s and track times from these! nice work!
Old Feb 28, 2005 | 04:54 PM
  #55
How much did the whole turbo set-up.. intercooler, etc etc cost ya?
Old Feb 28, 2005 | 06:18 PM
  #56
Armageddon's Avatar
...with cheese.
Pricing and more info can be found at www.phamspeed.com
thanks for all the replys and compliments also!
Old Feb 28, 2005 | 06:40 PM
  #57
sb427f-car's Avatar
SSU'S Vice Mod
What tank do you have mounted in the back of the car?? Are you dry sumpped??
Old Feb 28, 2005 | 07:02 PM
  #58
Armageddon's Avatar
...with cheese.
Yea, thats a Nasty Nate sump tank. I'll let you know how everything turns out with that. The work looks nice, I just had some trouble getting a few pieces, we'll see how it turns out. He's a pretty standup guy for the most part. I know he stays busy.
Old Feb 28, 2005 | 07:08 PM
  #59
sb427f-car's Avatar
SSU'S Vice Mod
That piece looks trick. When I start to build the "hot rod" I'm probably going to build a new LS2 block, @ least 402, and more like poked too, so the dry sump intreguies me since I'd like to turn left and right a few times too, not just go straight. Still cant decided on big single or twins. Personally, I prefer to row my own, which has me leaning towards twins. How much did that tank cost you? You running an oil cooler back there too or is it up front? Does it have it's own cooling fins? What kind of sump system are you running (pan, pump, ect.) and how many stages?? I know, I'm bombarding you, but if I don't write them down now I'll forget them.
Old Feb 28, 2005 | 07:16 PM
  #60
NA$TY-TA's Avatar
Thats a sumped fuel tank......... looksgood man... can you give us some specs on your motor??
Kyle
