Intake Blew Apart!
Debated with mech and think you may have just had a bent valve that allowed a backfire on a rear cylinder. Cam overlap is something to consider, but unlikely. What were the cam specs?
How do your valves look on Cyl 7/8?
Does the bottom end rotate?
I believe it was an otherwise stock Z06
Chris
! ***** the valves, block and oil pump Anyone want to comment on Prochargers rattling cam bolts loose? I know it sounds far fetched, but this is the 2nd or 3rd Procharged car I've heard of this on.
Was it a stock cam?
If an aftermarket cam was installed, did you use new cam bolts? Loc-tite?
Was it a stock cam?
