PTC t-76gts now what
Old Feb 28, 2005 | 11:16 AM
Juiced's Avatar
Default PTC t-76gts now what
Ok i picked my turbo now i have to decide on a wastegate.
What would be a good waste gate to use for the car, i know i want to run it open atmoshphere,
What size should i be running, and who makes good ones. oh i need it to be adjustable from 0-20psi if possible.
Old Feb 28, 2005 | 11:25 AM
EightBall's Avatar
how much boost do you plan on running and on what displacement motor?
Old Feb 28, 2005 | 11:50 AM
Juiced's Avatar
10psi on a o-ringed 347 Pump Gas
16psi 100 Octane
20psi C-16+alky
Old Feb 28, 2005 | 11:58 AM
Zombie's Avatar
16psi 100 Octane
20psi C-16+alky
14 psi on 91 octane and 8.5:1 compression is not an issue. I've done 16 on many import cars in 110+ degree weather. I'd run 12 just to be safe though and use alky to do 18, but i'm crazy like that. C16 is for high boost, like 22+ psi or cheap insurance if your trying to push the limits. 20-22psi is pretty easy and safe to run on 100 unleaded if you got a good tune.
c16 + 5 more degrees advance sure makes for some fun though
Old Feb 28, 2005 | 12:06 PM
Juiced's Avatar
This is my DD so Safety Is my Greatest Concern I'm an Avid User Of Torco and will continue to run it even mixed in with race gas.
Old Feb 28, 2005 | 02:04 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
I would run either the HKS GT gate or Turbosmart Progate.
Jose
Old Feb 28, 2005 | 04:36 PM
eviltwins's Avatar
If you're only going to run 10 pounds of boost on pump gas and throw torco in everything you might as well stuff some 10:1 pistons in that motor of yours, because you'll make more power @ 10 psi on 10:1 than you will with 8.5:1, and 10 psi isn't even pushing a motor like that.
