offset Crank with F1R
Old Feb 28, 2005 | 01:04 PM
blackbelt's Avatar
Default offset Crank with F1R
I am probably going to be doing an Iron block set up with my new F1R setup. I was wondering If a offset stock crank would be up to the challenge. I am shooting for a 380. My goals are around 800 to the ground with alky injection. The shop thats doing has a lot of experience with it and build 1000 hp motors all the time. Will it live or should i just leave the crank alone. They are going to be doing that part of the work for free.
Old Feb 28, 2005 | 06:59 PM
sb427f-car's Avatar
SSU'S Vice Mod
What do you mean by an offset crank?? Are you talking about a crank with different throws in it, like 60*, 90*, 60* like the ford truck v-10s, or are you talking about the old PS trick to change the crank and engine firing order? Or are you talking about a crank that will make the engine fire bank to bank? instead of the left, right right left, right, left, left, right...or something like that...
Old Feb 28, 2005 | 07:21 PM
NA$TY-TA's Avatar
No he means grinding down the rod journals and giving the crank a longer stroke.. i.e. more cubes...... TSP did this alot.... do a search alot will come up.
Kyle
Old Feb 28, 2005 | 07:22 PM
Phate's Avatar
I believe that he is talking about offset grinding the crank to gain a little more stroke. I wouldn't do it, and I wouldn't run a stock crank in something making that kind of power to the tire. Go with a nice 4340 crank. The last thing you want to be driving over while making a pass in an 800hp car is your crank...and the oil that will be with it.
Old Feb 28, 2005 | 07:23 PM
Phate's Avatar
Damn it Kyle, you beat me too it...LOL
Old Feb 28, 2005 | 07:25 PM
NA$TY-TA's Avatar
Im good brother........... gotta be quick to beat me
Kyle
Old Feb 28, 2005 | 08:24 PM
blackbelt's Avatar
I heard the stock crank was up to the job?? is this not true???
Old Feb 28, 2005 | 08:53 PM
Phate's Avatar
Not at that power level, it will survive for a while (As proven by Matt H.), but why take chances. He never broke it, but is switching to a nice crank.
Old Mar 1, 2005 | 07:41 AM
sb427f-car's Avatar
SSU'S Vice Mod
Kyle
Or that too...I didn't think it was as complex as the things I posted.
Old Mar 1, 2005 | 08:40 AM
APD*98SS's Avatar
not worth the risk, just do it right. The Lunati kit has a 4.00 inch stroke crank and you can't break it
Old Mar 1, 2005 | 09:47 AM
SS00Blue's Avatar
The stock crank is absolutely up to that power level. No question! But you're talking about reducing the rod journal diameter to gain stroke. That will compromise the journal overlap with the main, and also weaken the overall strength of the rod journal. Not advisable.
If you want the strength, go to an aftermarket crank. APE has great prices on 4340 Callies cranks --->>> They're a Sponsor, so look to the left. *EDIT: er, the other left"
Now, if you want to go all bore, then get the 380 cubes that way, use heads with bigger valves with no worry of shrouding, and use the stock crank. That'll go down track all day long with no undue "speedbumps" along the way.
SC-
Old Mar 1, 2005 | 10:16 AM
GrahamHill's Avatar
Offset grinding is a stock spec type class trick. There are smarter ways to make 5 more hp.
BTW: "Extra Stroke" = like a tenth of an inch at the most I think. .090" specifically.
