Pics of my new twin setup
Old Mar 1, 2005 | 02:39 PM
99t66ls1's Avatar
The front fan is set all the way to the pass side of the car so there are only a couple of inches overlapping, same way i did it before and had no problems. If you look in the picture the wiring in the drivers front corner is relocated and when you move it there is a hole there, has to be opened up a little but its there.
Old Mar 1, 2005 | 02:46 PM
Kevin@W2W's Avatar
LS1TECH Sponsor
As long as they don't overlap too much I guess it would be alright
Just looking out for ya.
Old Mar 1, 2005 | 03:41 PM
eviltwins's Avatar
NO not even a cage im not really in to the safety thing, luckily our track here has a midnight drag thing where i can pretty much get away with anything.
Who needs safety, anyways
Old Mar 1, 2005 | 03:54 PM
99t66ls1's Avatar
Not me I dont think I would want to live if i wrecked id be out so much money
Old Mar 1, 2005 | 03:55 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Looks sharp, I wonder if that intake setup would net me some more ponies.
I'd be a little concerned about your fan solution other than that looks great.
Old Mar 1, 2005 | 03:56 PM
Shinobi'sZ's Avatar
Here are some pics of my new turbo setup in progress
Turbos are precision t67 p trims, one 76s trim shown in picture was just for mockup
Headers are 304 stainless 1 3/4 primaries
Will probably finish the whole setup by the end of the month, feel free to ask any questions.
Awesome setup...just thought I would share. I am using the PTK TT (full header/collector same primaries, and 2 7/8" down pipes) for my C5. The first pair of Turbos we tried were a pair of TE63Es. My engine is a forged 346cid and CR is 8.9:1. Although the TE63e (AR .58)made great power at 9lbs of boost they would not spool to max boost until 4000 rpms. I am switching out to PT52s, to drop the rpms to hopefully around 3200-3500 for max boost. I was just curious what size your motor is, and whether or not you are going to keep those very large Turbos on there. If its a 346cid, you have like 173cid per side to power each turbo...it will be 4500-5000 rpms before they ever spool up to max boost....unless of course it is a 427cid.
Thanks
Old Mar 1, 2005 | 04:01 PM
99t66ls1's Avatar
I ran my fans like this for all of last year with the same radiator and it never even sees 200 degrees, so im really not worried at all about overheating. It is stock cubes now but will probably not be for that much longer so ill be staying with the 67's and i dont really care if they are slow spooling ive never raced trying to keep the car under 5000 rpms.
Old Mar 1, 2005 | 04:09 PM
Shinobi'sZ's Avatar
Thats cool...I wasn't sure what the ultimate application was...I understand if it is for drag racing purposes only. Wouldn't care to ever have that on the street though. I would have kept the TE63e or TE64e on the kit if I wanted to always be above 5000rpms...but whats the use in a Z06 with a weak *** drivetrain...no solid axle makes it really tough to justify trying to make 1400hp.
What cam you running in there????
Old Mar 1, 2005 | 04:13 PM
99t66ls1's Avatar
I understand i still drive it around town a couple days a week, i dont think spool time really matters that much on the street, even with my 76 as soon as it would spool it would just blow the tires off even with et streets, it might be faster with no boost until 5000 on the streets at least you would be moving forward instead of sideways.
Old Mar 1, 2005 | 08:44 PM
Shinobi'sZ's Avatar
Good point. You can drive the car normal...then at the track launch her at 5000 rpms and say good bye.
Old Mar 1, 2005 | 09:24 PM
JZ 97 SS 1500's Avatar
LS1TECH Sponsor
Kevin, did the 52's arrive yet??
Jose
Old Mar 1, 2005 | 09:28 PM
  #32
LS1Tech Co-Founder
How high you plan to turn the engine?
Old Mar 1, 2005 | 11:46 PM
  #33
Green Thunder's Avatar
Love the headers! Very nice setup!
Old Mar 3, 2005 | 01:46 PM
  #34
99t66ls1's Avatar
6700 for now if i go to a solid roller probably 7200.
Old Mar 3, 2005 | 02:20 PM
  #35
Cyborg's Avatar
Looks F'n sweet!
Old May 20, 2005 | 09:17 PM
  #36
White.Lightning's Avatar
Turbo's RULE!!!!!!!
Andy
Old May 20, 2005 | 11:22 PM
  #37
Crazyplaya182's Avatar
PM SENT
Old May 21, 2005 | 02:04 AM
  #38
liv2race's Avatar
hey i cant remember your name but i have talked to you before at the midnight drags up at rocky mount raceway i have the 94 383z with the front end conversion, plus turbo. anyways, are you sticking with the stock 6 speed or did you go to the 200r4 like you were talking about? as well as you rear did you blow the 10 bolt out of that thing yet?
Old May 22, 2005 | 04:40 PM
  #39
99t66ls1's Avatar
Ya it is still a 6 speed, it now has a 9 inch i sheared all the pinion teeth off this winter on the stock rear.
Old May 23, 2005 | 09:44 AM
  #40
NA$TY-TA's Avatar
PM was sent....
Kyle
