Crank case pressure
Old Mar 1, 2005 | 08:09 AM
Silver moose's Avatar
Default Crank case pressure
Whats the best way to stop crankcase pressure and where to get the parts?
Old Mar 1, 2005 | 08:48 AM
Justin98TransAm's Avatar
I beleive most people here are running breathers or a catchcan. I use two breatheres in the rear, and a PCV Valve up front. Unless your talking about a vacuum then i don't think there are many people doing that here.
Old Mar 1, 2005 | 10:37 AM
ls1290's Avatar
Dumb Ass Vette Moderator
If have a breather installed, is there really any point of having the PCV valve
Keith
Old Mar 1, 2005 | 10:54 AM
Boostaholic's Avatar
Of course the BEST way to do it is with a external vacc pump or dry sump oil pump, both of thoes things will run a little bit of cash though.
Old Mar 1, 2005 | 02:37 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
You mean 'what is the best way to alleviate or reduce crankcase pressure.'
You need to vent it, not recirculate it. Or use a vacuum pump setup which is at this point still custom stuff.
Old Mar 1, 2005 | 02:53 PM
y2khawk's Avatar
correct ring gap
Old Mar 10, 2005 | 10:42 PM
GrannySShifting's Avatar
No kiddin Matt
Maybe "what best way to deal with crankcase pressure with stock rings lol Matt you know of any brass or something PCV valves that might allow a partial stock style PCV setup to be used when not under boost?
Old Mar 10, 2005 | 11:38 PM
MadMike93TA's Avatar
Originally Posted by GrannySShifting
No kiddin Matt
I've heard of guys running the PCV line to the intake side of the supercharger where there will be constant vacc... But I'd do a pump...
Old Mar 11, 2005 | 07:24 PM
383ysi's Avatar
I've got 2 hoses 3/4'' from the valve covers to my exhaust, and check valves to keep it from coming back up. I think it works great.
