F1 on a street car?
Brett.
What you need for a supercharger is a different pully to adjust the boost level, you should be able to make as little boost as you want, you can also get a blowoff valve which relieves pressure on the s/c and intake pipes when the throttle blade is closed, but that isn't really a boost control device either.
Brett.
he made 822 on 93 pump gas though its off the car with an F-1R coming soon
with a conservative tune, the motor will handle alot more than 7 lbs, but you will have to have address the fuel side of things. Bigger injectors are a must as well as a tuner to adjust the fuel and timing.
You should be able to make the type of power you want with no problem.
A larger cam will not necessarily bleed off pressure ... this is controlled more by the lobe separation and overlap than the actual duration ... even though usually larger duration figures will tend to increase overlap, this is not always the case if the cam is designed for forced induction ...
-Geoff
