Question for harlan
Old Mar 1, 2005 | 04:03 PM
99t66ls1's Avatar
Default Question for harlan
Are you running a ford or a gm tps with your 105, also does either one have the same voltage range as the stock tps
Old Mar 1, 2005 | 04:10 PM
y2khawk's Avatar
ford
the are all just potentiometers, with the 5V feed from the PCM.
Old Mar 1, 2005 | 04:16 PM
99t66ls1's Avatar
Did you have to modify the tps at all or will it work with the factory pcm, when wired correctly.
Old Mar 1, 2005 | 04:20 PM
y2khawk's Avatar
as long as you get the supply and ground side of the sensor correct it plays (ie the signal voltage goes from low to high with increasing position)
Old Mar 1, 2005 | 04:22 PM
99t66ls1's Avatar
Right but is the voltage of the ford sensor at wot different than the stock tps at wot? Do you get what i mean is the scale the same or similar as the tps moves.
Old Mar 1, 2005 | 04:27 PM
ESR's Avatar
ESR
LS1TECH Sponsor
Default ....
okay now im curious your question has my attention which TB are you using harlan(ford part number or what is it off of)? as long as the wiring for ground etc is done correctly its plug and play? Thats what your saying right
Old Mar 1, 2005 | 04:29 PM
ESR's Avatar
ESR
LS1TECH Sponsor
Default ,,,,,,,
also does that tb also bolt up directly to ls6 or any other intake?
Old Mar 1, 2005 | 04:38 PM
99t66ls1's Avatar
It is a wilson 105 mm accufab also makes one and no they will not bolt up to an ls1 intake, they have a square 4 bolt pattern
Old Mar 1, 2005 | 04:41 PM
ESR's Avatar
ESR
LS1TECH Sponsor
Default tb
ok my next question would be I have a weiand intake could it safely be taped for the bolts? I could just port out the actually TB opening on the intake.
