SHift points & Rev Limiter settings with FI? Questions
Old Mar 4, 2005 | 05:22 PM
Arkangel77's Avatar
Default SHift points & Rev Limiter settings with FI? Questions
OK hear is the deal. I know that with the turbo the car will tack up a LOT faster. I have added a bit to my rev limiter BUT I still am hitting the rev limiter everytime I try to run it. Its gotten better BUT still not right? My Question is this - How much higher is your rev limiter set after your shift points? If you shift at 6200 RPM's where is your Rev limiter set at? I am looking to get some feedback from several folks so please let me know what yours is at. I just want to see what others are having to run there at. Thnaks for the help folks, Lata, Ark
Old Mar 4, 2005 | 05:32 PM
Boostaholic's Avatar
This depends on the driver, keep bumping your shift light down till you quit hitting the rev limiter and go from there.
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
If you get wheelspin, you can instantly hit the rev limiter. Ideally the rev limiter should be set at a point where you are not (a) making more power and (b) at an rpm beyond which you consider unsafe for your engine combo.
My rev limiter is set at 7200, I probably could make more power but I am unsure of the limits of the stock oiling system.
Old Mar 4, 2005 | 07:25 PM
John_D.'s Avatar
Depends on how loose your converter is. I keep about a 300rpm buffer, and that's just with a 3000rpm stall.
The more power you make, the easier it is to run over. Because there is a mph table for the shift too. Both have to be met for a shift to happen.
Just because you are at the rpms in the table, unless you are also at the mph, the pcm won't shift yet.
Old Mar 4, 2005 | 07:33 PM
Arkangel77's Avatar
Boostaholic - I dont have a SHift Lite - I let the Trany do it!
Pro Stock John - Ya figured it ouwl take some tunning and some trial and eror?
John_D. - I got a 2800 vigilantee and I got like 500 rpm difference and I am still hitting the rev limiter.
Thanks for the help guys, Lata, Ark
