6.0 LQ9 heads?
Old Feb 4, 2005 | 12:27 AM
solobaric's Avatar
Default 6.0 LQ9 heads?
Are the 6.0 lq9 heads the ones some of you boosted guys are using? If so, will they work as is, or is any P&P required? I have a chance to pick some up super cheap, but don't know if they will work for my TT setup.
Old Feb 4, 2005 | 01:41 AM
F8L Z71's Avatar
12 Second Truck Club
I use em on my 5.3L truck.
The LQ9 and LQ4 heads are the same. If you are getting them for under $500 then you're doin good.
Old Feb 4, 2005 | 05:19 AM
smokinHawk's Avatar
ya, go for it, great mod for the buck, definatly worth it.
only think you need to do is use the 4.0 bore gaskets
Old Feb 5, 2005 | 12:43 AM
solobaric's Avatar
Will they work with CC918 springs?
Old Feb 5, 2005 | 01:04 AM
F8L Z71's Avatar
I'm using the 918s. My new heads are going to be completely different but the 918s worked for what I used to have. Just don't get real agressive on the cam or else those wont be enough with a lot of boost.
Old Mar 3, 2005 | 11:28 AM
mdhmi's Avatar
Yes, but are the 6.0L heads worthwhile for FI even if you don't port or polish them?
Mark
Old Mar 3, 2005 | 11:38 AM
NA$TY-TA's Avatar
Mark
I believe its the compression drop most people look at when they add them to a stock motor when the heads are still in stock form.
I run LQ9 317 casting 6.0L ported heads.
Kyle
Old Mar 3, 2005 | 02:22 PM
NoGo's Avatar
The compression drop is worth the addition of the heads alone.......especially with a turbo setup.
Strap the heads on and crank up the boost!
Old Mar 3, 2005 | 04:46 PM
everx's Avatar
my question is where do u find them that cheap and do u have to have certain valve springs to go along with the heads. well any help would be greatly appreciated
Old Mar 3, 2005 | 05:09 PM
EightBall's Avatar
The type of valve spring depends on the cam you are using. I'm using a cam with under .600 lift so the comp 918s were fine for me.
I got mine off ebay complete for $300 back in October.
Old Mar 3, 2005 | 05:20 PM
NA$TY-TA's Avatar
There was a set in the for sale section i believe....... Swap out the springs and go for it....
Kyle
Old Mar 3, 2005 | 07:38 PM
Badzracing's Avatar
I'm selling a set....look in the classified section. Ferrea valves and comp cams components ( inl. titanium retainers).
Old Mar 3, 2005 | 08:18 PM
Ryan K's Avatar
Pathological Modifier
Also, the 6.0L 317 casting DO flow better than stock LS1 heads. They have the same port design as the LS6 head.
Old Mar 3, 2005 | 08:59 PM
NA$TY-TA's Avatar
yep....... 2nd that....
Old Mar 3, 2005 | 10:17 PM
mdhmi's Avatar
Kyle, did you do a before/after 6.0L head results dyno? How much, if any, did your boost drop when you added the 6.0L's?
Thanks,
Mark
Old Mar 4, 2005 | 09:41 AM
TSDuke's Avatar
Here is a set on ebay.
http://cgi.ebay.com/ebaymotors/ws/eB...958262983&rd=1
Old Mar 4, 2005 | 07:50 PM
NA$TY-TA's Avatar
Thanks,
Mark
Sorry i went with a new shortlock at the same time........ back in the early days people would see about a 2-3 psi drop but HP would stay right about the same..... so the motor wasnt working as hard to make the same power and the restriction to flow was down.. ie boost.
Kyle
