qustion about a turbo setup??
Old Mar 6, 2005 | 05:18 PM
kevin dixon's Avatar
Default qustion about a turbo setup??
Ok now i have a good knowledge on turbos i have a 95 eclipes and have done a lot of work to that.
and my 76 chevy is fast but...well you know
check out my truck http://www.cardomain.com/id/localboyz
well i am going to transplant a ls1 into her and whant to twin turbo
now i just whant to know if someone makes a header for a setup like this
if not i have made one for my car.
and should i go intenral or extenral?
and turbo?? now i know you are just say it depends on set up sooo if you could just gide me
the search is down now
Old Mar 6, 2005 | 05:50 PM
Boostaholic's Avatar
What power level are you looking for?
Is this a drag setup? Street? Street/Strip?
Old Mar 7, 2005 | 06:53 PM
I would just like 450 to 500
but would like to have room to expand
Old Mar 7, 2005 | 06:55 PM
and a street/strip
but more street
Old Mar 7, 2005 | 08:29 PM
spike1n1's Avatar
Have you looked into head/cam + n20 combo's?
Old Mar 8, 2005 | 05:34 AM
gogogadgetcar's Avatar
you could use internal gates if you wanted, you won't need very big turbo's either
to make that much power a single would be much more economical
I would say make your own manifolds. You will have all that space under the hood to play with.
good luck
Old Mar 8, 2005 | 04:12 PM
yea small turbo's would work but size are we talking about?
I am not into this type of displacent, put could i use like a twin 16g big turbo's like on my eclipes??
or go with a 20g with like 50% trim??
amd i want to run twin turbo's you know it is just a must!!!
Old Mar 8, 2005 | 06:00 PM
ya i here ya on that twin turbo just roles off the tonge so welll
as far as mitsu turbo's go the TD06 series look like they would work well so do T04B S3 trim
