I think I smoked it already
Old Mar 7, 2005 | 05:01 AM
Wolfee's Avatar
Default I think I smoked it already
Went out for a ride the other day and got on it a little bit, just a couple quick hits. I seen about 10 lbs and jumped off very quickly. When I get home I had to do a little burn out in the garage, just to hear the echo I went back out yesterday and took it for a quick ride, thing is shaking pretty bad and you deffinately feel it with little load. Anybody want to guess what happened, I figure I smoked a piston already because I still didn't have a tune and she probably went a little lean. I figure it's time to save for the better heads and bottom end now but does this sound familiar to anyone???
Wolfee
Old Mar 7, 2005 | 07:03 AM
KraZy's Avatar
You hit 10lbs with no tuning?!!! If I had to guess I'd say she's blown.
Old Mar 7, 2005 | 07:34 AM
Tiago's Avatar
pull the plugs and inspect.
Old Mar 7, 2005 | 07:55 AM
Wolfee's Avatar
Happened pretty quick, **** happens!
Wolfee
Old Mar 7, 2005 | 09:07 AM
sb427f-car's Avatar
SSU'S Vice Mod
"Damnit Kenny!!!"
Old Mar 7, 2005 | 09:14 AM
trtturbo's Avatar
Are you intercoolerd or have meth inj? Did you have your wastegate set to run that much boost? That sucks. You didnt have time to enjoy it at all.
Old Mar 7, 2005 | 10:05 AM
Wolfee's Avatar
I'm OBX intercooled, no meth injection. I thought the spring thats in it was supposed to be 7 lbs. I guss not I'm gonna pull the plugs (TR6's) tonight and hope one of them burnt/broke but I doubt it!
Wolfee
Old Mar 7, 2005 | 10:12 AM
trtturbo's Avatar
Maybe you will get lucky and you only closed up a gap or two. You do have your boost reference going to the side of the wastgate, and not the top right?
Old Mar 7, 2005 | 10:34 AM
Armageddon's Avatar
...with cheese.
Sorry about your luck, do what Billy said and make sure your wastegate has no obstruction on the top. Anything over that hole will keep the plunger from opening, which in turn keeps boost from bleeding off. The skies the limit!
Old Mar 7, 2005 | 11:24 AM
Zombie's Avatar
10 psi intercooled on a 67 tubo required me to pull the timing a peak tq to 11 degrees, stock it's around 24-26 degrees. You definately were detonating the **** out of it. I really hope for your sake it's only a plug gap issue. The tune is so important to the life of the motor.
Old Mar 7, 2005 | 12:44 PM
MelloYellow's Avatar
Don't drive FI above 3k rpm without a tune.
Old Mar 7, 2005 | 12:59 PM
WS-Sick's Avatar
You just couldn't resist could you? I hope you have no trouble finding the problem.
Old Mar 7, 2005 | 02:30 PM
aluminumblockCock's Avatar
sounds like something that would happen to me
Old Mar 7, 2005 | 03:12 PM
Wnts2Go10O's Avatar
sounds like u fried somethin..
Old Mar 7, 2005 | 03:20 PM
BoostedWS7's Avatar
thats beat....
Old Mar 8, 2005 | 07:55 AM
Wolfee's Avatar
It's official, I broke a ring land or cracked #4 piston. I done a compression check on her last night and all cylinders had above 160lbs except #4, it only had about 50'ish. I will now be installing Forged rods and pistons along with LS6 heads and intake. May be a long while though cause I don't have any cash for it right now.
Wolfee
Old Mar 8, 2005 | 08:28 AM
Wet 1's Avatar
Man, that sucks. Why would you beat on the engine w/o doing a tune first???
Old Mar 8, 2005 | 10:06 AM
Wolfee's Avatar
That's like saying why did I have unprotected sex with my wife before we got married?
Wolfee
Old Mar 8, 2005 | 11:47 AM
KraZy's Avatar
Wolfee
Why?! Did one of your ********* lose compression?
Dont sweat it man, good excuse to build that block up.
Old Mar 8, 2005 | 12:01 PM
Zombie's Avatar
It sucks that you killed it, but it was your own fault. There is no reason that a stock ls1 can't make 500-600 rwhp for 15-20k miles and be reliable. The stock setup is very strong.
I don't understand why people get so antsy to go blow up their cars. Almost everyone I know who adds nitrous or boost blows up their car within a few hours to a few weeks. Power is a drug.
Hope you can get it rebuilt soon and doesn't cost too much. Don't boost til you tune it.
